"May the fork be with you": novel metrics to analyze collaboration on GitHub - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Multi–repository software projects are becoming more and more popular, thanks to web–based facilities such as GitHub. Code and process metrics generally assume a single reposi-tory must be analyzed, in order to measure the characteris-tics of a codebase. Thus they are not apt to measure how much relevant information is hosted in multiple repositories contributing to the same codebase. Nor can they feature the characteristics of such a distributed development pro-cess. We present a set of novel metrics, based on an original classification of commits, conceived to capture some interest-ing aspects of a multi–repository development process. We also describe an efficient way to build a data structure that allows to compute these metrics on a set of Git reposito-ries. Interesting outcomes, obtained by applying our metrics on a large sample of projects hosted on GitHub, show the usefulness of our contribution.
Biazzini14b.pdf (3.73 Mo) Télécharger le fichier
hal-01085400 , version 1 (25-11-2014)
Marco Biazzini, Benoit Baudry. "May the fork be with you": novel metrics to analyze collaboration on GitHub. Proceedings of the 5th International Workshop on Emerging Trends in Software Metrics (WETSoM 2014), Jun 2014, Hyderabad, India. pp.37 - 43, ⟨10.1145/2593868.2593875⟩. ⟨hal-01085400⟩
286 Consultations
624 Téléchargements
