Lectures on Quasiconformal Mappings, 2006. ,
DOI : 10.1090/ulect/038
Network Flows: Theory, Algorithms, and Applications, 1993. ,
Using dynamic programming for solving variational problems in vision, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.12, issue.9, pp.855-867, 1990. ,
DOI : 10.1109/34.57681
The correlated correspondence algorithm for unsupervised registration of nonrigid surfaces, Proc. Neural Information Processing Systems, 2004. ,
Shape matching and object recognition using shape contexts, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.4, pp.509-522, 2002. ,
DOI : 10.1109/34.993558
Shape Matching and Object Recognition Using Low Distortion Correspondences, 2005 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (CVPR'05), pp.26-33, 2005. ,
DOI : 10.1109/CVPR.2005.320
A method for registration of 3-D shapes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.2, pp.239-256, 1992. ,
DOI : 10.1109/34.121791
Markov Random Fields for Vision and Image Processing, 2011. ,
Pseudo-Boolean optimization, Discrete Applied Mathematics, vol.123, issue.1-3, pp.155-225, 2002. ,
DOI : 10.1016/S0166-218X(01)00341-9
URL : https://hal.archives-ouvertes.fr/hal-01150533
Convex Optimization, 2004. ,
The Mathematical Theory of Finite Element Methods, 2007. ,
Generalized multidimensional scaling: A framework for isometry-invariant partial surface matching, Proc. National Academy of Sciences, pp.1168-1172, 2006. ,
DOI : 10.1073/pnas.0508601103
Expression-Invariant Representations of Faces, IEEE Transactions on Image Processing, vol.16, issue.1, pp.1042-1053, 2004. ,
DOI : 10.1109/TIP.2006.884940
Numerical Geometry of Non-Rigid Shapes, 2008. ,
DOI : 10.1007/978-0-387-73301-2
Global non-rigid alignment of 3-D scans, ACM Trans. Graph, vol.26, 2007. ,
A Survey Of Free-Form Object Representation and Recognition Techniques, Computer Vision and Image Understanding, vol.81, issue.2, pp.166-210, 2001. ,
DOI : 10.1006/cviu.2000.0889
Feature correspondence and deformable object matching via agglomerative correspondence clustering, Proc. IEEE Int'l Conf. Computer Vision, 2009. ,
Progressive graph matching: Making a move of graphs via probabilistic voting, Proc. IEEE Conf. Computer Vision and Pattern Recognition, 2012. ,
Mean shift: a robust approach toward feature space analysis, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.24, issue.5, pp.603-619, 2002. ,
DOI : 10.1109/34.1000236
Balanced graph matching, Proc. Neural Information Processing Systems, 2007. ,
A tensor-based algorithm for high-order graph matching, Proc. IEEE Conf. Computer Vision and Pattern Recognition, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01063322
Riemann Surfaces, 2004. ,
Approximate MRF Inference Using Bounded Treewidth Subgraphs, Proc. European Conf. Computer Vision, pp.385-398, 2012. ,
DOI : 10.1007/978-3-642-33718-5_28
TriangleFlow: Optical Flow with Triangulation-Based Higher-Order Likelihoods, Proc. European Conf. on Computer Vision, 2010. ,
DOI : 10.1007/978-3-642-15558-1_20
Non-Rigid Registration Under Isometric Deformations, Symposium on Geometry Processing, pp.1449-1457, 2008. ,
DOI : 10.1111/j.1467-8659.2008.01285.x
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.674.6909
Establishing Local Correspondences towards Compact Representations of Anatomical Structures, International Conference, 2003. ,
DOI : 10.1007/978-3-540-39903-2_113
Higher-order clique reduction in binary graph cut, 2009 IEEE Conference on Computer Vision and Pattern Recognition, 2009. ,
DOI : 10.1109/CVPR.2009.5206689
CUDA (compute unified device architecture), 2006. ,
Blended intrinsic maps, Proc. of SIGGRAPH 2011), pp.79-80, 2011. ,
Minimizing Nonsubmodular Functions with Graph Cuts-A Review, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.7, pp.1274-1279, 2007. ,
DOI : 10.1109/TPAMI.2007.1031
Beyond pairwise energies: Efficient optimization for higher-order MRFs, 2009 IEEE Conference on Computer Vision and Pattern Recognition, 2009. ,
DOI : 10.1109/CVPR.2009.5206846
MRF Energy Minimization and Beyond via Dual Decomposition, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.33, issue.3, pp.531-552, 2011. ,
DOI : 10.1109/TPAMI.2010.108
URL : https://hal.archives-ouvertes.fr/hal-00856311
Performance vs computational efficiency for optimizing single and dynamic MRFs: Setting the state of the art with primal-dual strategies, Computer Vision and Image Understanding, vol.112, issue.1, pp.14-29, 2008. ,
DOI : 10.1016/j.cviu.2008.06.007
URL : https://hal.archives-ouvertes.fr/hal-00918699
A Framework for Efficient Structured Max-Margin Learning of High-Order MRF Models, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.37, issue.7, pp.1425-1441, 2015. ,
DOI : 10.1109/TPAMI.2014.2368990
URL : https://hal.archives-ouvertes.fr/hal-01245673
Hyper-graph matching via reweighted random walks, CVPR 2011, 2011. ,
DOI : 10.1109/CVPR.2011.5995387
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.398.4627
A spectral technique for correspondence problems using pairwise constraints, Tenth IEEE International Conference on Computer Vision (ICCV'05) Volume 1, pp.1482-1489, 2005. ,
DOI : 10.1109/ICCV.2005.20
Semi-supervised learning and optimization for hypergraph matching, 2011 International Conference on Computer Vision, 2011. ,
DOI : 10.1109/ICCV.2011.6126507
Möbius voting for surface correspondence, ACM Trans. Graph, vol.2872, issue.3, pp.1-7212, 2009. ,
Functional maps, ACM Transactions on Graphics, vol.31, issue.4, pp.1-3011, 2012. ,
DOI : 10.1145/2185520.2185526
One Point Isometric Matching with the Heat Kernel, Computer Graphics Forum, vol.27, issue.5, pp.1555-1564, 2010. ,
DOI : 10.1111/j.1467-8659.2010.01764.x
URL : https://hal.archives-ouvertes.fr/hal-00543885
Non-rigid registration using distance functions, Computer Vision and Image Understanding, vol.89, issue.2-3, pp.142-165, 2003. ,
DOI : 10.1016/S1077-3142(03)00010-9
Computing Discrete Minimal Surfaces and Their Conjugates, Experimental Mathematics, vol.3, issue.1, pp.15-36, 1993. ,
DOI : 10.2307/1970625
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.17.6708
Texture mapping progressive meshes, Proceedings of the 28th annual conference on Computer graphics and interactive techniques , SIGGRAPH '01, pp.409-416, 2001. ,
DOI : 10.1145/383259.383307
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.114.8663
Probabilistic Subgraph Matching Based on Convex Relaxation, Energy Minimization Methods in Computer Vision and Pattern Recognition (EMMCVPR), 2005. ,
DOI : 10.1007/11585978_12
Simultaneous point matching and 3D deformable surface reconstruction, 2010 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2010. ,
DOI : 10.1109/CVPR.2010.5539827
URL : http://infoscience.epfl.ch/record/148055
Topologically-robust 3D shape matching based on diffusion geometry and seed growing, CVPR 2011, 2011. ,
DOI : 10.1109/CVPR.2011.5995455
URL : https://hal.archives-ouvertes.fr/inria-00590280
Mesh Parameterization Methods and Their Applications, Foundations and Trends?? in Computer Graphics and Vision, vol.2, issue.2, pp.105-171, 2006. ,
DOI : 10.1561/0600000011
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.225.1016
As-rigid-as-possible surface modeling, Symposium on Geometry Processing, pp.109-116, 2007. ,
Deformation transfer for triangle meshes, SIGGRAPH, pp.399-405, 2004. ,
DOI : 10.1145/1186562.1015736
Intrinsic Shape Matching by Planned Landmark Sampling, Eurographics, pp.543-552, 2011. ,
DOI : 10.1111/j.1467-8659.2011.01879.x
Isometric registration of ambiguous and partial data, 2009 IEEE Conference on Computer Vision and Pattern Recognition, pp.1185-1192, 2009. ,
DOI : 10.1109/CVPR.2009.5206775
Non-rigid Shape Matching Using Geometry and Photometry, Proc. Asian Conf. Computer Vision, 2009. ,
DOI : 10.1007/978-3-642-12297-2_62
URL : https://hal.archives-ouvertes.fr/hal-00711070
Solving Markov Random Fields using semi definite programming, Ninth Int'l Workshop on Artificial Intelligence and Statistics, 2003. ,
Feature Correspondence Via Graph Matching: Models and Global Optimization, Proc. European Conf. on Computer Vision, pp.596-609, 2008. ,
DOI : 10.1007/978-3-540-88688-4_44
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.146.4872
Face transfer with multilinear models, ACM Transactions on Graphics, vol.24, issue.3, pp.426-433, 2005. ,
DOI : 10.1145/1073204.1073209
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.220.9158
Discrete Minimum Distortion Correspondence Problems for Non-rigid Shape Matching, International Conference on Scale Space and Variational Methods in Computer Vision (SSVM), 2011. ,
DOI : 10.1007/978-3-642-24785-9_49
URL : https://hal.archives-ouvertes.fr/inria-00498591
Markov Random Field modeling, inference & learning in computer vision & image understanding: A survey, Computer Vision and Image Understanding, vol.117, issue.11, pp.1610-1627, 2013. ,
DOI : 10.1016/j.cviu.2013.07.004
URL : https://hal.archives-ouvertes.fr/hal-00858390
3D Knowledge-Based Segmentation Using Pose-Invariant Higher-Order Graphs, International Conference, Medical Image Computing and Computer Assisted Intervention (MICCAI), 2010. ,
DOI : 10.1007/978-3-642-15711-0_24
URL : https://hal.archives-ouvertes.fr/hal-00856051
Viewpoint invariant 3D landmark model inference from monocular 2D images using higher-order priors, 2011 International Conference on Computer Vision, 2011. ,
DOI : 10.1109/ICCV.2011.6126258
URL : https://hal.archives-ouvertes.fr/hal-00856131
Conformal Geometry and Its Applications on 3D Shape Matching, Recognition, and Stitching, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.29, issue.7, pp.1209-1220, 2007. ,
DOI : 10.1109/TPAMI.2007.1050
High Resolution Tracking of Non-Rigid Motion of Densely Sampled 3D Data Using Harmonic Maps, Proc. IEEE Int'l Conf. Computer Vision, 2005. ,
DOI : 10.1007/s11263-007-0063-y
Revisiting the Linear Programming Relaxation Approach to Gibbs Energy Minimization and Weighted Constraint Satisfaction, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.32, issue.8, pp.1474-1488, 2010. ,
DOI : 10.1109/TPAMI.2009.134
A high-resolution 3D dynamic facial expression database, 2008 8th IEEE International Conference on Automatic Face & Gesture Recognition, 2008. ,
DOI : 10.1109/AFGR.2008.4813324
3D Non-rigid Surface Matching and Registration Based on Holomorphic Differentials, Proc. European Conf. on Computer Vision, 2008. ,
DOI : 10.1007/978-3-540-88690-7_1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.221.4769
A generic deformation model for dense nonrigid surface registration: a higher-order MRF-based approach, Proc. IEEE Int'l Conf. Computer Vision, pp.3360-3367, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00856323
Dense non-rigid surface registration using high-order graph matching, 2010 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, pp.382-389, 2010. ,
DOI : 10.1109/CVPR.2010.5540189
URL : https://hal.archives-ouvertes.fr/hal-00856064
Intrinsic dense 3D surface tracking, CVPR 2011, 2011. ,
DOI : 10.1109/CVPR.2011.5995513
URL : https://hal.archives-ouvertes.fr/hal-00856137
Harmonic maps and their applications in surface matching, Proc. IEEE Conf. Computer Vision and Pattern Recognition, 1999. ,
12 3.2.1 Deformation constraints, p.13 ,
