Mean field analysis for inhomogeneous bike sharing systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2012
In the paper, bike sharing systems with stations having a finite capacity are studied as stochastic networks. The inhomogeneity is modeled by clusters. We use a mean field limit to compute the limiting stationary distribution of the number of bikes at the stations. This method is an alternative to analytical methods. It can be used even if a closed form expression for the stationary distribution is out of reach as illustrated on a variant. Both models are compared. A practical conclusion is that avoiding empty or full stations does not improve overall performance.
revision_FrickerGastMohamed_velib.pdf (551.52 Ko) Télécharger le fichier
hal-01086055 , version 1 (21-11-2014)
Paternité - Pas d'utilisation commerciale
Christine Fricker, Nicolas Gast, Hanene Mohamed. Mean field analysis for inhomogeneous bike sharing systems. AofA, Jul 2012, Montreal, Canada. ⟨10.46298/dmtcs.3006⟩. ⟨hal-01086055⟩
1377 Consultations
1571 Téléchargements
