Global stability of an epidemic model with two infected stages and mass-action incidence - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue BIOMATH Année : 2014
—The goal of this paper is the establishment of the global asymptotic stability of the model SI with two classes of infected stages and with varying total population size. The incidence used is the mass-action incidence given by (β 1 I 1 + β 2 I 2) S /N . Existence and uniqueness of the endemic equilibrium is established when the basic reproduction number is greater than one. A Lyapunov function is used to prove the stability of the disease free equilibrium, and the Poincarré-Bendixson theorem allows to prove the stability of the endemic equilibrium when it exists.
213-1968-1-PB.pdf (598.16 Ko) Télécharger le fichier
hal-01086101 , version 1 (21-11-2014)
Mamadou Lamine Diouf, Abderrahman Iggidr, Mamadou Sy. Global stability of an epidemic model with two infected stages and mass-action incidence. BIOMATH, 2014, 3 (1), pp.1--8. ⟨10.11145/j.biomath.2014.07.211⟩. ⟨hal-01086101⟩
389 Consultations
229 Téléchargements
