New interface
Conference papers
Minimal time control of the two tanks gradostat model under cascade inputs constraint
Abstract : We study the minimum time control problem of a series of two interconnected chemostats under the input constraint u(2) <= u(1), where u(i) are the respective dilution rates in the tanks. This constraint brings controllability issues in the study of the optimal strategies. We encounter this difficulty by splitting the state domain into two sub-domains, one with no lack of controllability of the target, and its complementary is such that any optimal control fulfills u(1) = u(2). We explicit the complete optimal synthesis that depends on the position of the target with respect to a semi-permeable curve that passes through a steady-state singular point.
Complete list of metadata
https://hal.inria.fr/hal-01086152
Contributor : Alain Rapaport Connect in order to contact the contributor
Submitted on : Saturday, November 22, 2014 - 5:32:16 PM
Last modification on : Tuesday, October 25, 2022 - 4:17:14 PM
Identifiers
Citation
Terence Bayen, Alain Rapaport, Matthieu Sebbah. Minimal time control of the two tanks gradostat model under cascade inputs constraint. European Control Conference ECC2014, Université de Strasbourg (Unistra). France, FRA. IEEE Control Systems Society., Jun 2014, Strasbourg, France. pp.1256 - 1261, ⟨10.1109/ECC.2014.6862148⟩. ⟨hal-01086152⟩
Share
Metrics
Record views
275
