Introduction toSocialRadio Case Studies and Perspectives
In this paper, we introduce a Social Radio platform designed to support contextual communication between communities. Radio communication was no longer used for information broadcast using different communication channels. The same concept is used in this work but for different purposes. We set up a microblogging community channel to report, comment or simply vote some events. In order to understand the concept we detail a scenario in the epidemic field.
Informatique [cs]
