Homotopy Bisimilarity for Higher-Dimensional Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
We introduce a new category of higher-dimensional automata in which the morphisms are functional homotopy simulations, i.e. functional simulations up to concurrency of independent events. For this, we use unfoldings of higher-dimensional automata into higher-dimensional trees. Using a notion of open maps in this category, we define homotopy bisimilarity. We show that homotopy bisimilarity is equivalent to a straight-forward generalization of standard bisimilarity to higher dimensions, and that it is finer than split bisimilarity and incomparable with history-preserving bisimilarity.
1409.5865v1.pdf (298.57 Ko) Télécharger le fichier
hal-01087294 , version 1 (25-11-2014)
  • HAL Id : hal-01087294 , version 1
Uli Fahrenberg, Axel Legay. Homotopy Bisimilarity for Higher-Dimensional Automata. [Research Report] Inria Rennes. 2014. ⟨hal-01087294⟩
384 Consultations
92 Téléchargements
