An Information Flow Monitor for a Core of DOM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose and prove sound a novel, purely dynamic, flow-sensitive monitor for securing information flow in an imperative language extended with DOM-like tree operations, that we call Core DOM. In Core DOM, as in the DOM API, tree nodes are treated as first-class values. We take advantage of this feature in order to implement an information flow control mechanism that is finer-grained than previous approaches in the literature. Furthermore, we extend Core DOM with additional constructs to model the behavior of live collections in the DOM Core Level 1 API. We show that this kind of construct effectively augments the observational power of an attacker and we modify the proposed monitor so as to tackle newly introduced forms of information leaks.
coreDom.pdf (524.83 Ko) Télécharger le fichier
hal-01087375 , version 1 (25-11-2014)
  • HAL Id : hal-01087375 , version 1
Ana Almeida Matos, José Fragoso Santos, Tamara Rezk. An Information Flow Monitor for a Core of DOM: Introducing references and live primitives. Symposium on Trustworthy Global Computing (TGC), Sep 2014, Rome, Italy. ⟨hal-01087375⟩
Collections
INRIA INRIA2
80 Consultations
97 Téléchargements
