Comparisons between implicit and explicit discrete-time implementations of equivalent-control-based sliding mode controllers: input and output chattering suppression via the implicit method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
This paper presents a set of experimental results concerning the sliding mode control of an electro-pneumatic system. The controller is implemented via a micro-processor as a discrete-time input. Three discrete-time control strategies are considered for the implementation of the discontinuous part of the sliding mode controller: explicit discretizations with and without saturation, and an implicit discretization (that is very easy to implement with a projection on the interval [−1, 1]). While the explicit implementation is known to generate numerical chattering, the implicit one is expected to significantly reduce chattering while keeping the accuracy. The experimental results reported in this work remarkably confirm that the implicit discrete-time sliding mode supersedes the explicit ones, with several important features: chattering in the control input is almost eliminated (while the explicit and saturated controllers behave like high-frequency bang-bang inputs), the input magnitude depends only on the perturbation size and is independent of the controller gain and sampling time. On the contrary the explicit controller shows obvious chattering for all sampling times, its magnitude increases as the controller gain increases, and it does not reduce when the sampling period augments. The tracking errors arecomparable for both methods, though the implicit method keeps the precision when the control gain increases, which is not the case for the explicit one. Introducing a saturation in the explicit controller does not allow to significantly improve the explicit controller behaviour.
Wang_Brogliato_etal.pdf (1.82 Mo) Télécharger le fichier
hal-01087400 , version 1 (26-11-2014)
  • HAL Id : hal-01087400 , version 1
Bin Wang, Bernard Brogliato, Vincent Acary, Ahcene Boubakir, Franck Plestan. Comparisons between implicit and explicit discrete-time implementations of equivalent-control-based sliding mode controllers: input and output chattering suppression via the implicit method. [Research Report] Inria Grenoble Rhône-Alpes. 2014. ⟨hal-01087400⟩
687 Consultations
156 Téléchargements
