Specification and Deployment of Integrated Security Policies for Outsourced Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a well-founded language allowing in one hand data owners to easily specify their security and utility requirements over the data to be outsourced and in an another hand to formalize the set of security mechanisms that can be used for the protection of out-sourced data. Based on the formalization of security and utility require-ments and security mechanisms properties, we formally identify the best mechanisms, and the best way to combine them to get the best trade-off between utility and security.
Article.pdf (366.27 Ko) Télécharger le fichier
hal-01087467 , version 1 (26-11-2014)
Anis Bkakria, Frédéric Cuppens, Nora Cuppens-Bouhlahia, David Gross-Amblard. Specification and Deployment of Integrated Security Policies for Outsourced Data. 28th Annual IFIP WG 11.3 Working Conference on Data and Applications Security and Privacy (DBSec '14), Jul 2014, Vienne, Austria. pp.17 - 32, ⟨10.1007/978-3-662-43936-4_2⟩. ⟨hal-01087467⟩
502 Consultations
159 Téléchargements
