Journal articles
Component-based Verification using Incremental design and Invariants
Abstract : We propose invariant-based techniques for the efficient verification of safety and deadlock-freedom properties of component-based systems. Components and their interactions are described in the BIP language. Global invariants of composite components are obtained by combining local invariants of their constituent components with interaction invariants that take interactions into account.We study new techniques for computing interaction invariants. Some of these techniques are incremental, i.e., interaction invariants of a composite hierarchically structured component are computed by reusing invariants of its constituents. We formalize incremental construction of components in the BIP language as the process of building progressively complex components by adding interactions (synchronization constraints) to atomic components. We provide sufficient conditions ensuring preservation of invariants when new interactions are added. When these conditions are not satisfied, we propose methods for generating new invariants in an incremental manner by reusing existing invariants from the constituents in the incremental construction. The reuse of existing invariants reduces considerably the overall verification effort.The techniques have been implemented in the D-Finder toolset. Among the experiments conducted, we have been capable of verifying safety properties and deadlock-freedom of sub-systems of the functional level of the DALA autonomous robot. This work goes far beyond the capacity of existing monolithic verification tools.
Document type :
Journal articles
Complete list of metadata
Cited literature [67 references]  Display  Hide  Download
https://hal.inria.fr/hal-01087682
Contributor : Uli Fahrenberg Connect in order to contact the contributor
Submitted on : Wednesday, November 26, 2014 - 2:56:52 PM
Last modification on : Wednesday, April 6, 2022 - 3:12:07 PM
Long-term archiving on: : Friday, April 14, 2017 - 7:52:13 PM
File
sosym.pdf
Identifiers
Citation
Saddek Bensalem, Marius Bozga, Axel Legay, Thanh-Hung Nguyen, Joseph Sifakis, et al.. Component-based Verification using Incremental design and Invariants. Software and Systems Modeling, Springer Verlag, 2014, pp.1-25. ⟨10.1007/s10270-014-0410-8⟩. ⟨hal-01087682⟩
Share
Metrics
Record views
466
Files downloads
326
