An analysis of the impact of multi-threading on communication performance, 2009 IEEE International Symposium on Parallel & Distributed Processing, 2009. ,
DOI : 10.1109/IPDPS.2009.5160893
URL : https://hal.archives-ouvertes.fr/inria-00381670
A multicore-enabled multirail communication engine, 2008 IEEE International Conference on Cluster Computing, pp.316-321, 2008. ,
DOI : 10.1109/CLUSTR.2008.4663788
URL : https://hal.archives-ouvertes.fr/inria-00327158
MT-MPI, Proceedings of the 28th ACM international conference on Supercomputing, ICS '14 ,
DOI : 10.1145/2597652.2597658
Quantifying the potential benefit of overlapping communication and computation in largescale scientific applications Quantifying Performance Benefits of Overlap Using MPI-2 in a Seismic Modeling Application, Proceedings of the 2006 ACM/IEEE conference on Supercomputing Proceedings of the 24th ACM International Conference on Supercomputing, ser. ICS '10, pp.17-25, 2006. ,
Prospects for truly asynchronous communication with pure MPI and hybrid MPI/OpenMP on current supercomputing platforms ,
Open MPI: A Flexible High Performance MPI, The 6th Annual International Conference on Parallel Processing and Applied Mathematics, 2005. ,
DOI : 10.1007/11752578_29
RDMA read based rendezvous protocol for MPI over InfiniBand, Proceedings of the eleventh ACM SIGPLAN symposium on Principles and practice of parallel programming , PPoPP '06, pp.32-39, 2006. ,
DOI : 10.1145/1122971.1122978
Improving Communication Progress and Overlap in MPI Rendezvous Protocol over RDMA-enabled Interconnects, 2008 22nd International Symposium on High Performance Computing Systems and Applications, pp.95-101, 2008. ,
DOI : 10.1109/HPCS.2008.10
Asynchronous MPI for the masses, 1302. ,
Message progression in parallel computing - to thread or not to thread?, 2008 IEEE International Conference on Cluster Computing, pp.213-222, 2008. ,
DOI : 10.1109/CLUSTR.2008.4663774
Improving Reactivity and Communication Overlap in MPI Using a Generic I/O Manager, EuroPVM/MPI, ser. LNCS Recent Advances in Parallel Virtual Machine and Message Passing Interface, pp.170-177, 2007. ,
DOI : 10.1007/978-3-540-75416-9_27
URL : https://hal.archives-ouvertes.fr/inria-00177167
A scalable and generic task scheduling system for communication libraries, 2009 IEEE International Conference on Cluster Computing and Workshops, 2009. ,
DOI : 10.1109/CLUSTR.2009.5289169
URL : https://hal.archives-ouvertes.fr/inria-00408521
Web and File Server Comparison: Microsoft Windows NT Server 4 ,
I'll do it later: Softirqs, tasklets, bottom halves, task queues, work queues and timers, Linux.conf.au, 2003. ,
Reducing run queue contention in shared memory multiprocessors, Computer, vol.30, issue.3, pp.82-89, 1997. ,
DOI : 10.1109/2.573673
hwloc: A Generic Framework for Managing Hardware Affinities in HPC Applications, 2010 18th Euromicro Conference on Parallel, Distributed and Network-based Processing, 2010. ,
DOI : 10.1109/PDP.2010.67
URL : https://hal.archives-ouvertes.fr/inria-00429889
Impact of NUMA Effects on High-Speed Networking with Multi-Opteron Machines, PDCS, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00175747
Lock-free linked lists using compare-and-swap, Proceedings of the fourteenth annual ACM symposium on Principles of distributed computing , PODC '95, pp.214-222, 1995. ,
DOI : 10.1145/224964.224988
Read-Copy Update: Using Execution History to Solve Concurrency Problems, Parallel and Distributed Computing and Systems, pp.509-518, 1998. ,
A framework for characterizing overlap of communication and computation in parallel applications, Cluster Computing, vol.20, issue.2, pp.75-90, 2008. ,
DOI : 10.1007/s10586-007-0046-3
OSU Micro-Benchmark Available: http: //mvapich.cse.ohio-state ,
Test suite for evaluating performance of multithreaded MPI communication, Parallel Computing, vol.35, issue.12, pp.608-617, 2009. ,
DOI : 10.1016/j.parco.2008.12.013
Dynamic optimization of communications over high speed networks, HPDC-15, The 15th IEEE International Symposium on High Performance Distributed Computing, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00110773
