HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Statistical Abstraction Boosts Design and Test Efficiency of Evolving Critical Systems
Axel Legay 1 Sean Sedwards 1
1 ESTASYS - Efficient STAtistical methods in SYstems of systems
Inria Rennes – Bretagne Atlantique , IRISA-D4 - LANGAGE ET GÉNIE LOGICIEL
Abstract : Monte Carlo simulations may be used to efficiently estimate critical properties of complex evolving systems but are nevertheless computationally intensive. Hence, when only part of a system is new or modified it seems wasteful to re-simulate the parts that have not changed. It also seems unnecessary to perform many simulations of parts of a system whose behaviour does not vary significantly. To increase the efficiency of designing and testing complex evolving systems we present simulation techniques to allow such a system to be verified against behaviourpreserving statistical abstractions of its environment. We propose a frequency domain metric to judge the a priori performance of an abstraction and provide an a posteriori indicator to aid construction of abstractions optimised for critical properties.
Document type :
Conference papers
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-01087858
Contributor : Sean Sedwards Connect in order to contact the contributor
Submitted on : Wednesday, November 26, 2014 - 10:10:48 PM
Last modification on : Wednesday, February 2, 2022 - 3:50:55 PM
Long-term archiving on: : Friday, February 27, 2015 - 12:55:13 PM
File
LegaySedwards2014.pdf
Identifiers
Citation
Axel Legay, Sean Sedwards. Statistical Abstraction Boosts Design and Test Efficiency of Evolving Critical Systems. Leveraging Applications of Formal Methods, Verification and Validation. Technologies for Mastering Change, EasyConference, Oct 2014, Corfu, Greece. pp.4 - 25, ⟨10.1007/978-3-662-45234-9_2⟩. ⟨hal-01087858⟩
Share
Metrics
Record views
135
Files downloads
108
