Abstract : One of the popular notions of equivalence for non-interleaving concurrent systems is history-preserving bisimilarity (hp-bisimilarity). Higher-dimensional automata (HDA) is a non-interleaving formalism for reasoning about behavior of concurrent systems, which provides a generalization (up to hp-bisimilarity) to the main models of concurrency proposed in the literature. Using open maps, we can show that hp-bisimilarity for HDA has a characterization directly in terms of (higher-dimensional) transitions of the HDA, rather than in terms of runs as e.g. for Petri nets. Our results imply decidability of hp-bisimilarity for finite HDA. They also put hp-bisimilarity firmly into the open-maps framework and tighten the connections between bisimilarity and weak topological fibrations.
https://hal.inria.fr/hal-01087933 Contributor : Uli FahrenbergConnect in order to contact the contributor Submitted on : Thursday, November 27, 2014 - 10:04:07 AM Last modification on : Thursday, January 20, 2022 - 5:33:24 PM Long-term archiving on: : Monday, March 2, 2015 - 9:18:59 AM
Uli Fahrenberg, Axel Legay. History-Preserving Bisimilarity for Higher-Dimensional Automata via Open Maps. LICS 2013 - Twenty-Eighth Annual ACM/IEEE Symposium on Logic in Computer Science, Jun 2013, New Orleans, United States. ⟨hal-01087933⟩
