Reachability analysis for timed automata using max-plus algebra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Logic and Algebraic Programming Année : 2012
We show that max-plus polyhedra are usable as a data structure in reachability analysis of timed automata. Drawing inspiration from the extensive work that has been done on difference bound matrices, as well as previous work on max-plus polyhedra in other areas, we develop the algorithms needed to perform forward and backward reachability analysis using max-plus polyhedra. To show that the approach works in practice and theory alike, we have created a proof-of-concept implementation on top of the model checker opaal.
jlp.pdf (531.26 Ko) Télécharger le fichier
hal-01087998 , version 1 (27-11-2014)
Qi Lu, Michael Madsen, Martin Milata, Søren Ravn, Uli Fahrenberg, et al.. Reachability analysis for timed automata using max-plus algebra. Journal of Logic and Algebraic Programming, 2012, 81, pp.298 - 313. ⟨10.1016/j.jlap.2011.10.004⟩. ⟨hal-01087998⟩
208 Consultations
128 Téléchargements
