ISS Interval Observers for Nonlinear Systems Transformed Into Triangular Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2014
Designing an interval observer with stability properties for nonlinear systems, which are not cooperative and not globally Lipschitz, is an open problem. This paper studies a general canonical structure for which interval observers with input to state stability (ISS) properties can be derived. This canonical block triangular nonlinear structure is rather general and may result from a change of coordinates or an output injection. We provide a general method for explicitly constructing framers for systems for which can be given such a structure. We also construct ISS interval observers when additional properties are satisfied. The systems we consider are in general not cooperative and not globally Lipschitz. We illustrate the constructions by designing a framer and an ISS interval observer for two models of bioreactors. Copyright © 2012 John Wiley & Sons, Ltd.
Automatique
hal-01088143 , version 1 (27-11-2014)
Frédéric Mazenc, Olivier Bernard. ISS Interval Observers for Nonlinear Systems Transformed Into Triangular Systems. International Journal of Robust and Nonlinear Control, 2014, 24 (7), pp.1241-1261. ⟨10.1002/rnc.2937⟩. ⟨hal-01088143⟩
338 Consultations
0 Téléchargements
