Nonlinear Control Under Nonconstant Delays Advances in Design and Control Series, Society for Industrial and Applied Mathematics, 2013. ,
Robustness of nonlinear predictor feedback laws to time- and state-dependent delay perturbations, Automatica, vol.49, issue.6, pp.1576-1590, 2013. ,
DOI : 10.1016/j.automatica.2013.02.050
Input-output linearization with delay cancellation for nonlinear delay systems: the problem of the internal stability, International Journal of Robust and Nonlinear Control, vol.28, issue.9, pp.909-937, 2003. ,
DOI : 10.1002/rnc.853
Stability of Neutral Systems with Commensurate Delays and Poles Asymptotic to the Imaginary Axis, SIAM Journal on Control and Optimization, vol.49, issue.2, pp.498-516, 2011. ,
DOI : 10.1137/090776275
URL : https://hal.archives-ouvertes.fr/hal-00782325
Lyapunov Technique and Backstepping for Nonlinear Neutral Systems, IEEE Transactions on Automatic Control, vol.58, issue.2, pp.512-517, 2013. ,
DOI : 10.1109/TAC.2012.2206709
URL : https://hal.archives-ouvertes.fr/hal-00761326
Nonlinear oscillations in a distributed network, Quarterly of Applied Mathematics, vol.24, issue.4, pp.289-301, 1967. ,
DOI : 10.1090/qam/99914
Further results on stability analysis of time-delayed systems with nonlinear uncertainties, Inernational Journal of Systems and Control, issue.2, pp.1-2010, 2010. ,
Introduction to the Theory and Applications of Functional Differential Equations, 1999. ,
DOI : 10.1007/978-94-017-1965-0
Introduction to Functional Differential Equations, Applied Mathematical Sciences, vol.99, 1993. ,
DOI : 10.1007/978-1-4612-4342-7
Nonnegative and Compartmental Dynamical Systems, 2010. ,
DOI : 10.1515/9781400832248
Stability and Dissipativity Theory for Nonnegative and Compartmental Dynamical Systems with Time Delay, Systems and Control Letters, vol.51, issue.5, pp.355-361, 2004. ,
DOI : 10.1007/978-3-642-18482-6_29
Delay Compensation for Nonlinear, Adaptive, and PDE Systems. Systems and Control: Foundations and Applications, 2009. ,
On the Liapunov???Krasovskii methodology for the ISS of systems described by coupled delay differential and difference equations, Automatica, vol.44, issue.9, pp.2266-2273, 2008. ,
DOI : 10.1016/j.automatica.2008.01.010
Lyapunov???Krasovskii functionals and application to input delay compensation for linear time-invariant systems, Automatica, vol.48, issue.7, pp.48-1317, 2012. ,
DOI : 10.1016/j.automatica.2012.04.002
URL : https://hal.archives-ouvertes.fr/hal-00761591
Stability results for systems described by coupled retarded functional differential equations and functional difference equations " . Nonlinear Analysis: Theory, Methods and Applications, pp.3339-3362, 2009. ,
Stability analysis of timevarying neutral time-delay systems, IEEE Transactions on Automatic Control, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01100340
On reduced-order interval observers for time-delay systems, Proceedings of the European Control Conference, pp.2116-2121, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00801809
Reduction Model Approach for Linear Time-Varying Systems With Delays, IEEE Transactions on Automatic Control, vol.59, issue.8, pp.59-2068, 2014. ,
DOI : 10.1109/TAC.2014.2320308
URL : https://hal.archives-ouvertes.fr/hal-01062761
Generating positive and stable solutions through delayed state feedback, Automatica, vol.47, issue.3, 2011. ,
DOI : 10.1016/j.automatica.2011.01.029
URL : https://hal.archives-ouvertes.fr/hal-00555497
Nonlinear Stabilization Under Sampled and Delayed Measurements, and With Inputs Subject to Delay and Zero-Order Hold, IEEE Transactions on Automatic Control, vol.57, issue.5, pp.1141-1154, 2012. ,
DOI : 10.1109/TAC.2011.2170451
Interval Observers for Time-Varying Discrete-Time Systems, IEEE Transactions on Automatic Control, vol.58, issue.12, pp.3218-3224, 2013. ,
DOI : 10.1109/TAC.2013.2263936
URL : https://hal.archives-ouvertes.fr/hal-00820937
Interval observers for discrete-time systems, International Journal of Robust and Nonlinear Control, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00761600
Representation of a Class of MIMO Systems via Internally Positive Realization, European Journal of Control, vol.16, issue.3, pp.291-304, 2010. ,
DOI : 10.3166/ejc.16.291-304
A New Approach to the Internally Positive Representation of Linear MIMO Systems, IEEE Transactions on Automatic Control, vol.57, issue.1, pp.119-134, 2012. ,
DOI : 10.1109/TAC.2011.2158170
New technique for stability analysis for time-varying systems with delay, 53rd IEEE Conference on Decision and Control, 2014. ,
DOI : 10.1109/CDC.2014.7039547
URL : https://hal.archives-ouvertes.fr/hal-01088244
Stabilizing time-varying systems with delay using linear Lyapunov functions and a positive systems approach, 2014. ,
Asymptotically Stable Interval Observers for Planar Systems With Complex Poles, IEEE Transactions on Automatic Control, vol.55, issue.2, pp.523-527, 2010. ,
DOI : 10.1109/TAC.2009.2037472
URL : https://hal.archives-ouvertes.fr/hal-00547800
Interval observers for linear time-invariant systems with disturbances, Automatica, vol.47, issue.1, pp.140-147, 2011. ,
DOI : 10.1016/j.automatica.2010.10.019
URL : https://hal.archives-ouvertes.fr/hal-00555464
Constructions of Strict Lyapunov Functions. Communications and Control Engineering Series, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00858552
Asymptotic stabilization for feedforward systems with delayed feedbacks, Automatica, vol.49, issue.3, pp.780-787, 2013. ,
DOI : 10.1016/j.automatica.2012.11.049
Compensation of State-Dependent Input Delay for Nonlinear Systems, IEEE Transactions on Automatic Control, vol.58, issue.2, pp.275-289, 2012. ,
DOI : 10.1109/TAC.2012.2208294
Compensation of state-dependent state delay for nonlinear systems, Systems and Control Letters, issue.8, pp.61-894, 2012. ,
Adaptive control for planar curve tracking under controller uncertainty, Automatica, vol.49, issue.5, pp.1411-1418, 2013. ,
DOI : 10.1016/j.automatica.2013.01.056
