Numerical Methods for Nonsmooth Dynamical Systems: Applications in Mechanics and Electronics, Lecture Notes in Applied and Computational Mechanics, vol.35, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00423530
A unified approach for inverse and direct dynamics of constrained multibody systems based on linear projection operator: applications to control and simulation, IEEE Transactions on Robotics, vol.21, issue.5, pp.834-849, 2005. ,
DOI : 10.1109/TRO.2005.851380
Dynamics and control of constrained mechanical systems in terms of reduced quasi-velocities, 2008 IEEE International Conference on Robotics and Automation, pp.19-23, 2008. ,
DOI : 10.1109/ROBOT.2008.4543371
Control of Redundant Mechanical Systems Under Equality and Inequality Constraints on Both Input and Constraint Forces, Journal of Computational and Nonlinear Dynamics, vol.6, issue.3, p.31013, 2011. ,
DOI : 10.1115/1.4002689
Traité de Mécanique Rationnelle, Dynamique des Systèmes?Mécanique Analytique, 1911. ,
The Dynamics of Discrete Mechanical Systems with Perfect Unilateral Constraints, Archive for Rational Mechanics and Analysis, vol.154, issue.3, pp.199-274, 2000. ,
DOI : 10.1007/s002050000105
URL : https://hal.archives-ouvertes.fr/hal-00111308
Mathematics: Theory, Facts, and Formulas with Application to Linear Systems Theory, Matrix, 2005. ,
The discrete null space method for the energy consistent integration of constrained mechanical systems, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.50-52, pp.5159-5190, 2005. ,
DOI : 10.1016/j.cma.2005.01.004
A geometric unification of constrained system dynamics, Multibody Syst. Dyn, vol.1, pp.1-21, 1997. ,
A Geometrical Interpretation and Uniform Matrix Formulation of Multibody System Dynamics, ZAMM, vol.81, issue.4, pp.247-259, 2001. ,
DOI : 10.1002/1521-4001(200104)81:4<247::AID-ZAMM247>3.0.CO;2-D
Energetically consistent simulation of simultaneous impacts and??contacts in??multibody systems with??friction, Multibody System Dynamics, vol.31, issue.3, pp.27-4510, 2009. ,
DOI : 10.1115/1.3167562
Mass-orthogonal formulation of equations of motion for multibody systems, ZAMP Zeitschrift f???r angewandte Mathematik und Physik, vol.31, issue.2, pp.169-182, 1991. ,
DOI : 10.1007/978-3-322-90942-8
Simulation of Constrained Mechanical Systems ??? Part I: An Equation of Motion, Journal of Applied Mechanics, vol.79, issue.4, p.41017, 2012. ,
DOI : 10.1115/1.4005572
Nonsmooth Impact Mechanics: Models, Dynamics and Control, Lecture Notes in Control and Information Sciences, vol.220, 1996. ,
On the control of finite-dimensional mechanical systems with unilateral constraints, IEEE Transactions on Automatic Control, vol.42, issue.2, pp.200-215, 1997. ,
DOI : 10.1109/9.554400
Nonsmooth Mechanics: Models, Dynamics and Control, Communications and Control Engineering, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-01236953
Absolute stability and the Lagrange???Dirichlet theorem with monotone multivalued mappings, Systems & Control Letters, vol.51, issue.5, pp.343-353, 2004. ,
DOI : 10.1016/j.sysconle.2003.09.007
URL : https://hal.archives-ouvertes.fr/inria-00071792
Dissipative Systems Analysis and Control, Communications and Control Engineering, 2007. ,
DOI : 10.1007/978-1-84628-517-2
URL : https://hal.archives-ouvertes.fr/hal-01338369
Analysis of a generalized kinematic impact law for multibody-multicontact systems, with application to the planar rocking block and chains of balls, Multibody System Dynamics, vol.465, issue.2107, pp.351-382, 2012. ,
DOI : 10.1098/rspa.2008.0520
URL : https://hal.archives-ouvertes.fr/hal-00825573
Inertial couplings between unilateral and bilateral holonomic constraints in frictionless Lagrangian systems, Multibody System Dynamics, vol.2, issue.6, pp.289-32510, 2013. ,
DOI : 10.1007/978-3-642-01100-9
URL : https://hal.archives-ouvertes.fr/hal-00825581
On the approximation of the elastic bounce problem on Riemannian manifolds, Journal of Differential Equations, vol.47, issue.2, pp.227-275, 1983. ,
DOI : 10.1016/0022-0396(83)90035-9
Collision of three balls on a plane, Computational Mechanics, vol.271, issue.2, pp.743-754, 2009. ,
DOI : 10.1007/978-3-662-04800-9
Perturbation Bounds of P-Matrix Linear Complementarity Problems, SIAM Journal on Optimization, vol.18, issue.4, pp.1250-1265, 2007. ,
DOI : 10.1137/060653019
Chocs de solides rigides, pp.98-104, 1998. ,
In: The Linear Complementarity Problem, SIAM Classics in Applied Mathematics, vol.60, 2009. ,
Singularity-Free Dynamic Equations of Open-Chain Mechanisms With General Holonomic and Nonholonomic Joints, IEEE Transactions on Robotics, vol.24, issue.3, pp.517-526, 2008. ,
DOI : 10.1109/TRO.2008.924250
A convergence result for a vibro-impact problem with a general inertia operator. Nonlinear Dyn, pp.361-38410, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01552482
Rigid bodies collisions, Physics Letters A, vol.204, issue.1, pp.33-41, 1995. ,
DOI : 10.1016/0375-9601(95)00418-3
Non-smooth Thermomechanics, 2002. ,
n Explicit Formulation of Singularity-Free Dynamic Equations of Mechanical Systems in Lagrangian Form---Part one: Single Rigid Bodies, Modeling, Identification and Control: A Norwegian Research Bulletin, vol.33, issue.2, pp.45-68, 2012. ,
DOI : 10.4173/mic.2012.2.2
An Indeterminate Problem in Classical Mechanics, The American Mathematical Monthly, vol.59, issue.5, pp.291-295, 1952. ,
DOI : 10.2307/2307502
Lectures in Analytical Mechanics, 1970. ,
New results on Painlev?? paradoxes, European Journal of Mechanics - A/Solids, vol.18, issue.4, pp.653-677, 1999. ,
DOI : 10.1016/S0997-7538(99)00144-8
Set-Valued Force Laws, Lecture Notes in Applied Mechanics, vol.1, 2001. ,
DOI : 10.1007/978-3-540-44479-4
An Introduction to Impacts, Nonsmooth Mechanics of Solids. CISM Courses and Lectures, pp.45-102, 2006. ,
DOI : 10.1007/978-3-211-48243-8_2
Energetic consistency conditions for standard impacts, Multibody System Dynamics, vol.41, issue.4, pp.77-11710, 2013. ,
Multiple impacts with friction in rigid multibody systems, Nonlinear Dynamics, vol.59, issue.3, pp.471-497, 1995. ,
DOI : 10.1007/BF00121109
A survey of equations of motion in terms of inertial quasi-velocities for serial manipulators, Archive of Applied Mechanics, vol.104, issue.I, pp.579-614, 2006. ,
A Variational Approach to Copositive Matrices, SIAM Review, vol.52, issue.4, pp.593-629, 2010. ,
DOI : 10.1137/090750391
URL : https://hal.archives-ouvertes.fr/hal-00629655
Fundamentals of Convex Analysis, 2001. ,
Impacts in a system with certain unilateral couplings, Journal of Applied Mathematics and Mechanics, vol.51, issue.4, pp.43-442, 1987. ,
DOI : 10.1016/0021-8928(87)90081-5
On multiple impact, Journal of Applied Mathematics and Mechanics, vol.59, issue.6, pp.887-902, 1995. ,
DOI : 10.1016/0021-8928(95)00122-0
Singularities in the dynamics of systems with non-ideal constraints, Journal of Applied Mathematics and Mechanics, vol.67, issue.2, pp.185-192, 2003. ,
DOI : 10.1016/S0021-8928(03)90004-9
Diagonalized Lagrangian robot dynamics, IEEE Transactions on Robotics and Automation, vol.11, issue.4, pp.571-584, 1995. ,
DOI : 10.1109/70.406941
URL : http://dshell.jpl.nasa.gov/References/pdf/innov-paper.pdf
An instantaneous eigenstructure quasivelocity formulation for nonlinear multibody dynamics, J. Astronaut. Sci, vol.45, pp.279-295, 1997. ,
On the Derivation of Equations of Motion, Journal of the Society for Industrial and Applied Mathematics, vol.13, issue.2, pp.487-492, 1965. ,
DOI : 10.1137/0113030
The Use of Kane's Dynamical Equations in Robotics, The International Journal of Robotics Research, vol.104, issue.2, pp.3-21, 1983. ,
DOI : 10.1115/1.3139699
Modeling of Impact in Multibody Systems: An Overview, Journal of Computational and Nonlinear Dynamics, vol.8, issue.2, p.21012, 2013. ,
DOI : 10.1115/1.4006202
Finite and impulsive motion of constrained mechanical systems via Jourdain's principle: discrete and hybrid parameter models, International Journal of Non-Linear Mechanics, vol.38, issue.6, pp.935-956, 2003. ,
DOI : 10.1016/S0020-7462(02)00039-2
Billiards: A Genetic Introduction to the Dynamics of Systems with Impacts, 1991. ,
The Theory of Matrices, 1985. ,
Treatment of impact with friction in planar multibody mechanical systems, Multibody System Dynamics, vol.6, issue.3, pp.203-227, 2001. ,
DOI : 10.1023/A:1012005130031
Passive Decomposition of Mechanical Systems With Coordination Requirement, IEEE Transactions on Automatic Control, vol.58, issue.1, pp.230-235, 2013. ,
DOI : 10.1109/TAC.2012.2203062
Periodic motion and bifurcations induced by the Painlev?? paradox, European Journal of Mechanics - A/Solids, vol.21, issue.5, pp.869-896, 2002. ,
DOI : 10.1016/S0997-7538(02)01231-7
URL : http://www.zfm.ethz.ch/~leine/papers/Leine %26 Brogliato %26 Nijmeijer - Periodic Motion and Bifurcations Induced by the Painleve Paradox.pdf
Stability and Convergence of Mechanical Systems with Unilateral Constraints, Lecture Notes in Applied and Computational Mechanics, vol.36, 2008. ,
DOI : 10.1007/978-3-540-76975-0
Simple mechanical control systems with constraints, IEEE Transactions on Automatic Control, vol.45, issue.8, pp.1420-1436, 2000. ,
DOI : 10.1109/9.871752
A unified geometric approach to modeling and control of constrained mechanical systems, IEEE Trans. Robot. Autom, vol.18, issue.4, pp.574-587, 2002. ,
Another form of equations of motion for constrained multibody systems, Nonlinear Dynamics, vol.10, issue.3, pp.465-470, 2008. ,
DOI : 10.1007/978-3-642-50995-7_8
On First-Order Decoupling of Equations of Motion for Constrained Dynamical Systems, Journal of Applied Mechanics, vol.62, issue.1, pp.216-222, 1995. ,
DOI : 10.1115/1.2895905
The Bounds on the Coefficients of Restitution for the Frictional Impact of Rigid Pendulum Against a Fixed Surface, Journal of Applied Mechanics, vol.77, issue.1, p.11006, 2010. ,
DOI : 10.1115/1.3172198
Analytical Mechanics, 2002. ,
DOI : 10.1007/978-3-540-45677-3
A unified variational model for the dynamics of perfect unilateral constraints, European Journal of Mechanics - A/Solids, vol.17, issue.5, pp.819-842, 1998. ,
DOI : 10.1016/S0997-7538(98)80007-7
Right-hand solutions of the differential equations of dynamics for mechanical systems with sliding friction, Journal of Applied Mathematics and Mechanics, vol.59, issue.6, pp.837-844, 1995. ,
DOI : 10.1016/0021-8928(95)00116-6
Feedback stabilization and tracking of constrained robots, IEEE Transactions on Automatic Control, vol.33, issue.5, pp.419-426, 1988. ,
DOI : 10.1109/9.1220
Generalization of the Energetic Coefficient of Restitution for Contacts in Multibody Systems, Journal of Computational and Nonlinear Dynamics, vol.3, issue.4, p.41008, 2008. ,
DOI : 10.1115/1.2960477
Impacts in multibody systems: modeling and experiments, Multibody System Dynamics, vol.63, issue.2, pp.163-176, 2008. ,
DOI : 10.1017/CBO9780511626432
Trajectory Tracking Control of Multiconstraint Complementarity Lagrangian Systems, IEEE Transactions on Automatic Control, vol.55, issue.6, pp.1300-1313, 2010. ,
DOI : 10.1109/TAC.2010.2042231
URL : https://hal.archives-ouvertes.fr/hal-00756307
Liaisons unilatérales sans frottement et chocs inélastiques. Frictionless unilateral constraints and inelastic shocks, C. R. Séances Acad. Sci., Sér. Méc.-Phys. Chim. Sci. Univers Sci. Terre, vol.2, issue.296, pp.1473-1476, 1983. ,
Unilateral Contact and Dry Friction in Finite Freedom Dynamics, Nonsmooth Mechanics and Applications. CISM Courses and Lectures, pp.1-82, 1988. ,
DOI : 10.1007/978-3-7091-2624-0_1
Some numerical methods in multibody dynamics: application to granular materials, Eur. J. Mech. A, Solids, vol.13, issue.4, pp.93-114, 1994. ,
Dynamics of Non-holonomic Systems. Am, Math. Soc, 1972. ,
Multiple Impacts in Dissipative Granular Chains, Lecture Notes in Applied and Computational Mechanics, vol.72, 2013. ,
DOI : 10.1007/978-3-642-39298-6
URL : https://hal.archives-ouvertes.fr/hal-00908612
Complementarity formulations and existence of solutions of dynamic multi-rigid-body contact problems with coulomb friction, Mathematical Programming, vol.14, issue.2, pp.199-226, 1996. ,
DOI : 10.1007/BFb0120929
CONTINUOUS DEPENDENCE ON DATA FOR VIBRO-IMPACT PROBLEMS, Mathematical Models and Methods in Applied Sciences, vol.359, issue.01, pp.1-41, 2005. ,
DOI : 10.1098/rsta.2001.0859
Oblique Frictional Impact of a Bar: Analysis and Comparison of Different Impact Laws, Nonlinear Dynamics, vol.6, issue.4, pp.361-383, 2005. ,
DOI : 10.1002/9783527618385
An Experimental and Theoretical Study of Perfect Multiple Contact Collisions in Linear Chains of Bodies, 2008. ,
Multibody Dynamics with Unilateral Contacts, 1996. ,
Convex Analysis, Princeton Landmarks in Mathematics, 1970. ,
DOI : 10.1515/9781400873173
Variational Analysis, Grundlehren der Mathematischen Wissenschaften, vol.317, 1998. ,
DOI : 10.1007/978-3-642-02431-3
Solution to indeterminate multipoint impact with frictional contact using constraints, Multibody System Dynamics, vol.14, issue.4, pp.313-330, 2012. ,
DOI : 10.1007/s11044-005-0269-0
Variational solutions to simultaneous collisions between multiple rigid bodies, 2010 IEEE International Conference on Robotics and Automation, pp.3-8, 2010. ,
DOI : 10.1109/ROBOT.2010.5509766
Conditions for uniqueness in simultaneous impact with application to mechanical design, 2012 IEEE International Conference on Robotics and Automation, pp.14-18, 2012. ,
DOI : 10.1109/ICRA.2012.6224737
The equations of motion of a system under the action of the impulsive constraints, Appl. Math. Mech, vol.9, issue.1, pp.51-60, 1988. ,
One???dimensional collisions and Chebyshev polynomials, American Journal of Physics, vol.45, issue.3, pp.255-259, 1977. ,
DOI : 10.1119/1.11003
On Dynamic Multi-Rigid-Body Contact Problems with Coulomb Friction, ZAMM - Journal of Applied Mathematics and Mechanics / Zeitschrift f??r Angewandte Mathematik und Mechanik, vol.9, issue.4, pp.267-279, 1997. ,
DOI : 10.1007/BF00249053
URL : http://www.cs.tamu.edu/faculty/trink/Papers/tr95003.ps.Z
An Efficient Newton-Type Iteration for the Numerical Solution of Highly Oscillatory Constrained Multibody Dynamic Systems, SIAM Journal on Scientific Computing, vol.19, issue.5, pp.1513-1534, 1998. ,
DOI : 10.1137/S1064827596297227
Study of the Planar Rocking-Block Dynamics With Coulomb Friction: Critical Kinetic Angles, Journal of Computational and Nonlinear Dynamics, vol.8, issue.2, p.21002, 2013. ,
DOI : 10.1115/1.4007056
URL : https://hal.archives-ouvertes.fr/hal-00825590
