A random testing approach using pushdown automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Software Testing, Verification and Reliability Année : 2014
Since finite automata are in general strong abstractions of systems, many test cases which are automata traces generated uniformly at ran-dom, may be un-concretizable. This paper proposes a method extending the abovementioned testing approach to pushdown systems providing finer abstractions. Using combinatorial techniques guarantees the uniformity of generated traces. In addition, to improve the quality of the test suites, the combination of coverage criteria with random testing is investigated. The method is illustrated within both structural and model-based testing contexts.
STVR-Hal.pdf (747.54 Ko) Télécharger le fichier
hal-01088712 , version 1 (28-11-2014)
Aloïs Dreyfus, Pierre-Cyrille Héam, Olga Kouchnarenko, Catherine Masson. A random testing approach using pushdown automata. Journal of Software Testing, Verification and Reliability, 2014, 24, pp.656 - 683. ⟨10.1002/stvr.1526⟩. ⟨hal-01088712⟩
264 Consultations
1386 Téléchargements
