New interface
Journal articles
Quasi-static Free-Boundary Equilibrium of Toroidal Plasma with CEDRES++: Computational Methods and Applications
Abstract : We present a comprehensive survey of the various computational methods in CEDRES++ for finding equilibria of toroidal plasma. Our focus is on free-boundary plasma equilib-ria, where either poloidal field coil currents or the temporal evolution of voltages in poloidal field circuit systems are given data. Centered around a piecewise linear finite element representation of the poloidal flux map, our approach allows in large parts the use of established numerical schemes. The coupling of a finite element method and a boundary element method gives consistent numerical solutions for equilibrium problems in unbounded domains. We formulate a new Newton method for the discretized non-linear problem to tackle the various non-linearities, including the free plasma boundary. The Newton method guarantees fast convergence and is the main building block for the inverse equilibrium problems that we can handle in CEDRES++ as well. The inverse problems aim at finding either poloidal field coil currents that ensure a desired shape and position of the plasma or at finding the evolution of the voltages in the poloidal field circuit systems that ensure a prescribed evolution of the plasma shape and position. We provide equilibrium simulations for the tokamaks ITER and WEST to illustrate the performance of CEDRES++ and its application areas.
Complete list of metadata
Cited literature [65 references]  Display  Hide  Download
https://hal.inria.fr/hal-01088772
Contributor : Holger Heumann Connect in order to contact the contributor
Submitted on : Monday, December 1, 2014 - 5:13:29 PM
Last modification on : Thursday, August 4, 2022 - 4:58:36 PM
Long-term archiving on: : Friday, April 14, 2017 - 11:06:08 PM
File
CedresRefPaper.pdf
Identifiers
Citation
Holger Heumann, Jacques Blum, Cedric Boulbe, Blaise Faugeras, Gael Selig, et al.. Quasi-static Free-Boundary Equilibrium of Toroidal Plasma with CEDRES++: Computational Methods and Applications. Journal of Plasma Physics, 2015, pp.35. ⟨10.1017/S0022377814001251⟩. ⟨hal-01088772⟩
Share
Metrics
Record views
678
Files downloads
650
