On the solution of the magnetic flux equation in an infinite domain, EPS. 8th Europhysics Conference on Computing in Plasma Physics, 1986. ,
Numerical studies of the Next European Torus via the PROTEUS code, 12th Conf. on Numerical Simulation of Plasmas, 1987. ,
The linearized CREATE-L plasma response model for the control of current, position and shape in tokamaks, Nuclear Fusion, vol.38, issue.5, p.723, 1998. ,
DOI : 10.1088/0029-5515/38/5/307
Design of next step tokamak: Consistent analysis of plasma performance flux composition and poloidal field system, 18th IAEA Fusion Energy Conference, 2000. ,
Magnetic Control of Tokamak Plasmas, 2008. ,
DOI : 10.1007/978-3-319-29890-0
The CRONOS suite of codes for integrated tokamak modelling, The CRONOS suite of codes for integrated tokamak modelling, p.43001, 2010. ,
DOI : 10.1088/0029-5515/50/4/043001
Symmetric finite element and boundary integral coupling methods for fluid-solid interaction, Quarterly of Applied Mathematics, vol.49, issue.1, pp.107-119, 1991. ,
DOI : 10.1090/qam/1096235
Numerical simulation of the plasma equilibrium in a Tokamak, Computer Physics Reports, vol.6, issue.1-6, 1987. ,
DOI : 10.1016/0167-7977(87)90015-3
Reconstruction of the equilibrium of the plasma in a Tokamak and identification of the current density profile in real time, Journal of Computational Physics, vol.231, issue.3, pp.960-980 ,
DOI : 10.1016/j.jcp.2011.04.005
URL : https://hal.archives-ouvertes.fr/hal-00419608
2014 Optimal control for quasi-static evolution of plasma equilibrium in tokamaks, Tech. Rep.. INRIA ,
The self-consistent equilibrium and diffusion code sced, Computer Physics Communications, vol.24, issue.3-4, pp.235-254, 1981. ,
DOI : 10.1016/0010-4655(81)90149-1
Jianxin 1992 Boundary element methods ,
The Finite Element Method for Elliptic Problems, studies in Mathematics and its Applications, 1978. ,
Three-dimensional anisotropic pressure free boundary equilibria, Three-dimensional anisotropic pressure free boundary equilibria, pp.1524-1533, 2009. ,
DOI : 10.1016/j.cpc.2009.04.006
Coupling of Finite and Boundary Element Methods for an Elastoplastic Interface Problem, SIAM Journal on Numerical Analysis, vol.27, issue.5, pp.1212-1226, 1990. ,
DOI : 10.1137/0727070
An inverse variable technique in the MHD-equilibrium problem, Computer Physics Reports, vol.2, issue.7, pp.341-387, 1985. ,
DOI : 10.1016/0167-7977(85)90002-4
Adaptive Mesh Computation of Magnetic Hydrodynamic Equilibrium, International Journal of Modern Physics C, vol.02, issue.01, pp.2-30, 1991. ,
DOI : 10.1142/S0129183191000056
2011 Shapes and geometries, Advances in Design and Control ,
An iterative metric method for solving the inverse tokamak equilibrium problem, Journal of Computational Physics, vol.37, issue.2, pp.183-204, 1980. ,
DOI : 10.1016/0021-9991(80)90020-0
The European Integrated Tokamak Modelling (ITM) effort: achievements and first physics results, Contributors, ITM- TF, the ASDEX Upgrade Team & Contributors, JET-EFDA 2014 The European Integrated Tokamak Modelling (ITM) effort: achievements and first physics results, p.43018 ,
DOI : 10.1088/0029-5515/54/4/043018
URL : https://hal.archives-ouvertes.fr/hal-01105065
Finite element approximation of nonlinear elliptic problems with discontinuous coefficients, ESAIM: Mathematical Modelling and Numerical Analysis, vol.24, issue.4, pp.457-500 ,
DOI : 10.1051/m2an/1990240404571
Multipole tokamak equilibria 2013 EFIT tokamak equilibria with toroidal flow and anisotropic pressure using the two-temperature guiding-centre plasma, Nuclear Fusion Nuclear Fusion, vol.13, issue.5311, p.113040, 1973. ,
The Uncoupling of Boundary Integral and Finite Element Methods for Nonlinear Boundary Value Problems, Journal of Mathematical Analysis and Applications, vol.189, issue.2, pp.442-461, 1995. ,
DOI : 10.1006/jmaa.1995.1029
Analyse numerique du champ magnetique d'un alternateur par elements finis et sur-relaxation ponctuelle non lineaire, Computer Methods in Applied Mechanics and Engineering, vol.3, issue.1, pp.55-85, 1974. ,
DOI : 10.1016/0045-7825(74)90042-5
Stationary symmetric magnetohydrodynamic flows, Physics of Plasmas, vol.4, issue.10, pp.3544-3564, 1994. ,
DOI : 10.1063/1.872251
Stefaan 2010 Advanced magnetohydrodynamics: with applications to laboratory and astrophysical plasmas ,
DOI : 10.1017/cbo9781139195560
Stefaan 2004 Principles of magnetohydrodynamics: with applications to laboratory and astrophysical plasmas ,
Toroidal Containment of a Plasma, Physics of Fluids, vol.10, issue.1, pp.137-154, 1958. ,
DOI : 10.1063/1.1761965
Hydromagnetic equilibria and force-free fields, Proceedings of the 2nd UN Conf. on the Peaceful Uses of Atomic Energy 31, 0190. ,
DOI : 10.1016/0891-3919(58)90139-6
Virginie 1999 Modélisation de l'´ equilibre d'un plasma de tokamak ,
Computation of MHD equilibria by a quasi-inverse finite hybrid element approach, Journal of Computational Physics, vol.73, issue.1, pp.168-182, 1987. ,
DOI : 10.1016/0021-9991(87)90112-4
Numerical study of tokamak equilibria with arbitrary flow, Physics of Plasmas, vol.11, issue.2, pp.604-614, 1994. ,
DOI : 10.1063/1.1637918
MHD equilibrium in non-circular tokamaks with field-shaping coil systems, Nuclear Fusion, vol.18, issue.11, p.1523, 1978. ,
DOI : 10.1088/0029-5515/18/11/005
The CEDRES++ equilibrium code and its application to ITER, JT-60SA and Tore Supra, Fusion Engineering and Design, vol.86, issue.6-8, pp.2011-1045 ,
DOI : 10.1016/j.fusengdes.2011.03.092
URL : https://hal.archives-ouvertes.fr/hal-00872280
Theory of plasma transport in toroidal confinement systems, Reviews of Modern Physics, vol.48, issue.2, pp.239-308, 1976. ,
DOI : 10.1103/RevModPhys.48.239
Coupling of Finite Elements and Boundary Elements in Electromagnetic Scattering, SIAM Journal on Numerical Analysis, vol.41, issue.3, pp.919-944, 2003. ,
DOI : 10.1137/S0036142901397757
Preconditioned descent algorithm for rapid calculations of magnetohydrodynamic equilibria, Journal of Computational Physics, vol.96, issue.1, pp.99-109, 1991. ,
DOI : 10.1016/0021-9991(91)90267-O
Two-dimensional transport of tokamak plasmas, Physics of Fluids, vol.22, issue.4, pp.731-742, 1979. ,
DOI : 10.1063/1.862654
Tokamak equilibrium reconstruction using Faraday rotation measurements, Nuclear Fusion, vol.28, issue.10, p.1871, 1988. ,
DOI : 10.1088/0029-5515/28/10/014
URL : http://infoscience.epfl.ch/record/120899
MHD stability in X-point geometry: simulation of ELMs, Nuclear Fusion, vol.47, issue.7, p.659, 2007. ,
DOI : 10.1088/0029-5515/47/7/016
Isoparametric Bicubic Hermite Elements for Solution of the Grad-Shafranov Equation, Proc. CP90 Conf. on Comp. Phys. p, p.371, 1991. ,
DOI : 10.1142/S0129183191000512
Computational methods in plasma physics, 2010. ,
DOI : 10.1201/EBK1439810958
Dynamic modeling of transport and positional control of tokamaks, Journal of Computational Physics, vol.66, issue.2, pp.481-507, 1986. ,
DOI : 10.1016/0021-9991(86)90077-X
Numerical determination of axisymmetric toroidal magnetohydrodynamic equilibria, Numerical determination of axisymmetric toroidal magnetohydrodynamic equilibria, pp.212-234, 1979. ,
DOI : 10.1016/0021-9991(79)90129-3
Computation of ideal MHD equilibria, Computer Physics Communications, vol.12, issue.1, pp.33-44, 1976. ,
DOI : 10.1016/0010-4655(76)90008-4
Equilibrium analysis of current profiles in tokamaks, Nuclear Fusion, vol.30, issue.6, p.1035, 1990. ,
DOI : 10.1088/0029-5515/30/6/006
Variational moment solutions to the Grad???Shafranov equation, Physics of Fluids, vol.24, issue.8, pp.1431-1440, 1981. ,
DOI : 10.1063/1.863562
Reconstruction of current profile parameters and plasma shapes in tokamaks, Nuclear Fusion, vol.25, issue.11, p.1611, 1985. ,
DOI : 10.1088/0029-5515/25/11/007
Optimal a priori estimates for higher order finite elements for elliptic interface problems, Applied Numerical Mathematics, vol.60, issue.1-2, pp.19-37, 2010. ,
DOI : 10.1016/j.apnum.2009.08.005
The Princeton spectral equilibrium code: PSEC, Journal of Computational Physics, vol.58, issue.3, pp.300-335, 1985. ,
DOI : 10.1016/0021-9991(85)90165-2
Magnetic analysis of non-circular cross-section tokamaks, Nuclear Fusion, vol.22, issue.6, p.813, 1982. ,
DOI : 10.1088/0029-5515/22/6/009
An analytic solution of the stationary MHD equations for a rotating toroidal plasma, Physics Letters A, vol.102, issue.3, pp.106-108, 1984. ,
DOI : 10.1016/0375-9601(84)90790-4
Acoustic and electromagnetic equations, Applied Mathematical Sciences, vol.144, 2001. ,
Self-consistent simulation of plasma scenarios for ITER using a combination of 1.5D transport codes and free-boundary equilibrium codes, Self-consistent H. Heumann et. al. simulation of plasma scenarios for iter using a combination of 1.5d transport codes and free-boundary equilibrium codes, p.113002, 2013. ,
DOI : 10.1088/0029-5515/53/11/113002
Plasma simulation studies using multilevel physics models, Physics of Plasmas, vol.6, issue.5, pp.1796-1803, 1994. ,
DOI : 10.1063/1.873437
Monotonicity-preserving interproximation of B???H-curves, Journal of Computational and Applied Mathematics, vol.196, issue.1, pp.45-57, 2006. ,
DOI : 10.1016/j.cam.2005.08.021
Anisotropic pressure effects on plasma equilibrium in toroidal systems, Plasma Physics and Controlled Fusion, vol.52, issue.6, p.65001, 2010. ,
DOI : 10.1088/0741-3335/52/6/065001
2014 GetFEM++, an open-source finite element library ,
p-and hp-finite element methods : theory and applications in solid and fluid mechanics, 2004. ,
On magnetohydrodynamical equilibrium configurations, Soviet Journal of Experimental and Theoretical Physics, vol.6, p.545, 1958. ,
Triangle: Engineering a 2D quality mesh generator and Delaunay triangulator, Applied Computational Geometry: Towards Geometric Engineering, 1996. ,
DOI : 10.1007/BFb0014497
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.40.9874
Coupling of finite elements and boundary elements for some nonlinear interface problems, Computer Methods in Applied Mechanics and Engineering, vol.101, issue.1-3, pp.61-72, 1992. ,
DOI : 10.1016/0045-7825(92)90015-C
Multiconstrained variational problems in magnetohydrodynamics: Equilibrium and slow evolution, Journal of Computational Physics, vol.106, issue.2, pp.269-285, 1993. ,
DOI : 10.1016/S0021-9991(83)71107-1
Solving electromagnetic problems using a novel symmetric FEM-BEM approach, IEEE Transactions on Magnetics, vol.42, issue.4, pp.583-586, 2006. ,
DOI : 10.1109/TMAG.2006.872489
Equilibrium analysis of tokamak discharges with anisotropic pressure, Plasma Physics and Controlled Fusion, vol.43, issue.11, p.1441, 2001. ,
DOI : 10.1088/0741-3335/43/11/302
