Optimized Distribution of Synchronous Programs via a Polychronous Model
—This paper presents a distribution methodology for synchronous programs, applied in particular on programs written in the Quartz language. The given program is first transformed into an intermediate model of guarded actions. After user-specified partitioning, the generated sub-models are transformed into Signal processes. Using the multi-clock calculation model of the Signal language, an optimized data-flow network can be automatically constructed. The optimization includes reducing the communication quantity and the computation load, with no change to the interface behaviors.
PAPER2014.pdf (104.69 Ko)
Télécharger le fichier
Optimized Distribution of Synchronous Programs via a Polychronous Model (MEMOCODE 2014).pdf (405.73 Ko)
