New interface
Conference papers
AIOCJ: A Choreographic Framework for Safe Adaptive Distributed Applications
Mila Dalla Preda 1, 2 Saverio Giallorenzo 1, 2 Ivan Lanese 1, 2 Jacopo Mauro 1, 2 Maurizio Gabbrielli 1, 2
1 FOCUS - Foundations of Component-based Ubiquitous Systems
CRISAM - Inria Sophia Antipolis - Méditerranée , DISI - Dipartimento di Informatica - Scienza e Ingegneria [Bologna]
Abstract : We present AIOCJ, a framework for programming distributed adap-tive applications. Applications are programmed using AIOC, a choreographic language suited for expressing patterns of interaction from a global point of view. AIOC allows the programmer to specify which parts of the application can be adapted. Adaptation takes place at runtime by means of rules, which can change during the execution to tackle possibly unforeseen adaptation needs. AIOCJ relies on a solid theory that ensures applications to be deadlock-free by construction also after adaptation. We describe the architecture of AIOCJ, the design of the AIOC language, and an empirical validation of the framework.
Document type :
Conference papers
Complete list of metadata
Cited literature [27 references]  Display  Hide  Download
https://hal.inria.fr/hal-01089187
Contributor : Jacopo Mauro Connect in order to contact the contributor
Submitted on : Monday, December 1, 2014 - 12:10:27 PM
Last modification on : Thursday, January 20, 2022 - 5:26:59 PM
Long-term archiving on: : Friday, April 14, 2017 - 11:44:29 PM
File
sle.pdf
Identifiers
Collections
Citation
Mila Dalla Preda, Saverio Giallorenzo, Ivan Lanese, Jacopo Mauro, Maurizio Gabbrielli. AIOCJ: A Choreographic Framework for Safe Adaptive Distributed Applications. SLE 2014, Sep 2014, Västerås, Sweden. pp.161 - 170, ⟨10.1007/978-3-319-11245-9_9⟩. ⟨hal-01089187⟩
Share
Metrics
Record views
254
Files downloads
90
