Actors: A conceptual foundation for concurrent objectoriented programming, Research Directions in Object-Oriented Programming, pp.49-74, 1987. ,
Programming Erlang: Software for a Concurrent World, 2007. ,
Computing: Software Environments and Tools, chapter Programming , Composing, Deploying, for the Grid, 2006. ,
Verification of Object-oriented Software: The KeY Approach, 2007. ,
DOI : 10.1007/978-3-540-69061-0
Parametric type classes, Proc. of LFP'92, pp.170-181, 1992. ,
DOI : 10.1145/141471.141536
Understanding fault-tolerant distributed systems, Communications of the ACM, vol.34, issue.2, pp.56-78, 1991. ,
DOI : 10.1145/102792.102801
A Complete Guide to the Future, ESOP, pp.316-330, 2007. ,
DOI : 10.1007/978-3-540-71316-6_22
Observable behavior of distributed systems: Component reasoning for concurrent objects, The Journal of Logic and Algebraic Programming, vol.81, issue.3, pp.227-256, 2012. ,
DOI : 10.1016/j.jlap.2012.01.003
A survey of rollback-recovery protocols in message-passing systems, ACM Computing Surveys, vol.34, issue.3, pp.375-408, 2002. ,
DOI : 10.1145/568522.568525
Java Concurrency in Practice, 2006. ,
Erlang-style error recovery for concurrent objects with cooperative scheduling, 2014. ,
Scala Actors: Unifying thread-based and event-based programming, Theoretical Computer Science, vol.410, issue.2-3, pp.202-220, 2009. ,
DOI : 10.1016/j.tcs.2008.09.019
URL : http://doi.org/10.1016/j.tcs.2008.09.019
MULTILISP: a language for concurrent symbolic computation, ACM Transactions on Programming Languages and Systems, vol.7, issue.4, pp.501-538, 1985. ,
DOI : 10.1145/4472.4478
Algebraic Data Types, Pattern Calculus, pp.149-160, 2009. ,
DOI : 10.1007/978-3-540-89185-7_14
ABS: A Core Language for Abstract Behavioral Specification, Proc. of FMCO 2010, pp.142-164, 2011. ,
DOI : 10.2498/cit.2002.01.01
Fault in the future, In COORDINA- TION LNCS, vol.6721, pp.1-15, 2011. ,
Is abstraction the key to computing?, Communications of the ACM, vol.50, issue.4, pp.36-42, 2007. ,
DOI : 10.1145/1232743.1232745
Controlling Reversibility in Higher-Order Pi, In CONCUR LNCS, vol.6901, pp.297-311, 2011. ,
DOI : 10.1007/11539452_31
Active object: an object behavioral pattern for concurrent programming, Pattern languages of program design 2, pp.483-499, 1996. ,
Promises: Linguistic support for efficient asynchronous procedure calls in distributed systems, PLDI, pp.260-267, 1988. ,
Open data types and open functions, Proc. of PPDP'06 Morris. CActive and Friends. Symbian Developer Network, pp.133-144, 2006. ,
Practical framework for contract-based concurrent object-oriented programming, 2007. ,
Rmi: The Remote Method Invocation Guide, 2001. ,
Better resource management with Java SE 7: Beyond syntactic sugar, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00611453
Type checking records and variants in a natural extension of ML, Proceedings of the 16th ACM SIGPLAN-SIGACT symposium on Principles of programming languages , POPL '89, pp.77-88, 1989. ,
DOI : 10.1145/75277.75284
JCoBox: Generalizing Active Objects to Concurrent Components, LNCS, vol.6183, pp.275-299, 2010. ,
DOI : 10.1007/978-3-642-14107-2_13
A note on distributed computing, MOS'96), pp.49-64, 1997. ,
DOI : 10.1007/3-540-62852-5_6
ABCL: An Object-Oriented Concurrent System, 1990. ,
