Evaluating Streaming Strategies for Event Processing across Infrastructure Clouds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Radu Tudoran
  • Fonction : Auteur
  • PersonId : 914308
Kate Keahey
  • Fonction : Auteur
  • PersonId : 884576
Pierre Riteau
  • Fonction : Auteur
  • PersonId : 961960
Sergey Panitkin
  • Fonction : Auteur
  • PersonId : 962194
Gabriel Antoniu
Infrastructure clouds revolutionized the way in which we approach resource procurement by providing an easy way to lease compute and storage resources on short notice, for a short amount of time, and on a pay-as-you-go basis. This new opportunity, however, introduces new performance trade-offs. Making the right choices in leveraging different types of storage available in the cloud is particularly important for applications that depend on managing large amounts of data within and across clouds. An increasing number of such applications conformto a pattern in which data processing relies on streaming the data to a compute platform where a set of similar operations is repeatedly applied to independent chunks of data. This pattern is evident in virtual observatories such as the Ocean Observatory Initiative, in cases when new data is evaluated against existing features in geospatial computations or when experimental data is processed as a series of time events. In this paper, we propose two strategies for efficiently implementing such streaming in the cloud and evaluate them in the contextof an ATLAS application processing experimental data. Our results show that choosing the right cloud configuration can improve overall application performance by as much as three times.
Informatique
CCGRID2014Chicago.pdf (542.3 Ko) Télécharger le fichier
hal-01089371 , version 1 (03-12-2014)
Radu Tudoran, Kate Keahey, Pierre Riteau, Sergey Panitkin, Gabriel Antoniu. Evaluating Streaming Strategies for Event Processing across Infrastructure Clouds. Cluster, Cloud and Grid Computing (CCGrid), 2014 14th IEEE/ACM International Symposium on, May 2014, Chicago, United States. pp.151 - 159, ⟨10.1109/CCGrid.2014.89⟩. ⟨hal-01089371⟩
398 Consultations
180 Téléchargements
