Principles and potential of the anaerobic digestion of waste-activated sludge, Progr Energ Combust Sci, vol.34, issue.6, pp.755-81, 2008. ,
Anaerobic co-digestion of fat, oil, and grease (FOG): a review of gas production and process limitations, Process Saf Environ Protect, vol.90, issue.3, pp.231-276, 2012. ,
Increased biogas production at wastewater treatment plants through co-digestion of sewage sludge with grease trap sludge from a meat processing plant, Bioresour Technol, vol.100, pp.79-85, 2009. ,
Co-digestion of grease trap sludge and sewage sludge, Waste Manage, vol.28, issue.6, pp.986-92, 2008. ,
Evaluation of different pre-hydrolysis times and enzyme pool concentrations on the biodegradability of poultry slaughterhouse wastewater with a high fat content, Water Sci Technol, vol.60, issue.1, pp.243-252, 2009. ,
Performance and molecular evaluation of an anaerobic system with suspended biomass for treating wastewater with high fat content after enzymatic hydrolysis, Bioresour Technol, vol.100, issue.24, pp.6170-6176, 2009. ,
Enzymatic prehydrolysis of high fat content dairy wastewater as a pretreatment for anaerobic digestion, Int J Environ Res, vol.6, issue.2, pp.475-80, 2012. ,
Estimation of hydrolysis parameters in full-scale anaerobic digesters, Biotechnol Bioeng, vol.102, issue.5, pp.1513-1533, 2009. ,
Modelling the effect of the OLR and OFMSW particle size on the performances of an anaerobic co-digestion reactor, Process Biochem, vol.46, issue.2, pp.557-65, 2011. ,
A comprehensive model of anaerobic bioconversion of complex substrates to biogas, Biotechnol Bioeng, vol.63, pp.363-72, 1999. ,
Standard methods for the examination of water and wastewater. 19th ed. Washington DC: American Public Health Association/American Water Works Association/Water Environment Federation, 1995. ,
Anaerobic co-digestion of FOG and sewage sludge: study of the process by Fourier transform infrared spectroscopy, Int Biodeterior Biodegr, vol.75, pp.1-6, 2012. ,
Determination of the hydrolysis constant in the biochemical methane potential test of municipal oslid waste, Environ Eng Sci, vol.29, issue.9, pp.848-54, 2012. ,
Effect of enzymes on anaerobic digestion of primary sludge and septic tank performance, Bioprocess Biosys Eng, vol.35, issue.9, pp.1577-89, 2012. ,
Anaerobic degradation of the various fractions of slaughterhouse wastewater, Biol Waste, vol.23, pp.117-159, 1988. ,
Anaerobic digestion of lipid-rich waste-effects of lipid concentration, Renew Energy, vol.32, pp.965-75, 2007. ,
