On the Discriminating Power of Testing Equivalences for Reactive Probabilistic Systems: Results and Open Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Testing equivalences have been deeply investigated on fully nondeterministic processes, as well as on processes featuring probabilities and internal nondeterminism. This is not the case with reactive probabilistic processes, for which it is only known that the discriminating power of probabilistic bisimilarity is achieved when admitting a copying capability within tests. In this paper, we introduce for reactive probabilistic processes three testing equivalences without copying, which are respectively based on reactive probabilistic tests, fully nondeterministic tests, and nondeterministic and probabilistic tests. We show that the three testing equivalences are strictly finer than probabilistic failure-trace equivalence, and that the one based on nondeterministic and probabilistic tests is strictly finer than the other two, which are incomparable with each other. Moreover, we provide a number of facts that lead us to conjecture that (i) may testing and must testing coincide on reactive probabilistic processes and (ii) nondeterministic and probabilistic tests reach the same discriminating power as probabilistic bisimilarity.
qest2014.pdf (387.37 Ko) Télécharger le fichier
hal-01089484 , version 1 (01-12-2014)
Marco Bernardo, Davide Sangiorgi, Valeria Vignudelli. On the Discriminating Power of Testing Equivalences for Reactive Probabilistic Systems: Results and Open Problems. QEST 2014, Sep 2014, Florence, Italy. pp.281 - 296, ⟨10.1007/978-3-319-10696-0_23⟩. ⟨hal-01089484⟩
Collections
INRIA INRIA2
102 Consultations
90 Téléchargements
