Better polynomials for GNFS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Computation Année : 2016
The general number field sieve (GNFS) is the most efficient algo-rithm known for factoring large integers. It consists of several stages, the first one being polynomial selection. The quality of the selected polynomials can be modelled in terms of size and root properties. We propose a new kind of polynomials for GNFS: with a new degree of freedom, we further improve the size property. We demonstrate the efficiency of our algorithm by exhibiting a better polynomial than the one used for the factorization of RSA-768, and a polynomial for RSA-1024 that outperforms the best published one.
sopt-20140905.pdf (209.03 Ko) Télécharger le fichier
hal-01089507 , version 1 (01-12-2014)
Shi Bai, Cyril Bouvier, Alexander Kruppa, Paul Zimmermann. Better polynomials for GNFS. Mathematics of Computation, 2016, 85, pp.12. ⟨10.1090/mcom3048⟩. ⟨hal-01089507⟩
1109 Consultations
811 Téléchargements
