Periodic meshes for the CGAL library
This work is motivated by the need for a 3D periodic mesh generator in various fields, such as material engineering or modeling of nano-structures. In this paper, we present a software package answering this need, and which will be made publicly available in the open source CGAL library.
Géométrie algorithmique [cs.CG]
IMR23_ResearchNote7_Pelle.pdf (2.38 Mo)
Télécharger le fichier
Format : Figure, Image
