Service-Oriented Architectures: From Design to Production Exploiting Workflow Patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In Service-Oriented Architectures (SOA), services are com-posed by coordinating their communications into a flow of interactions. Coloured Petri nets (CPN) offer a formal yet easy tool for modelling interactions in SOAs, however mapping abstract SOAs into executable ones requires a non-trivial and time-costly analysis. Here, we propose a methodology that maps CPN-modelled SOAs into Jolie SOAs (our tar-get language), exploiting a collection of recurring control-flow patterns, called Workflow Patterns, as composable blocks of the translation. We validate our approach with a realistic use case. In addition, we pragmat-ically asses the expressiveness of Jolie wrt the considered WPs.
Biotechnologie
Service-Oriented Architectures- From Design to Production Exploiting Workflow Patterns.pdf (756.71 Ko) Télécharger le fichier
hal-01090128 , version 1 (03-12-2014)
Maurizio Gabbrielli, Saverio Giallorenzo, Fabrizio Montesi. Service-Oriented Architectures: From Design to Production Exploiting Workflow Patterns. 11th International Symposium on Distributed Computing and Artificial Intelligence, Jun 2014, Salamanca, Spain. ⟨10.1007/978-3-319-07593-8_17⟩. ⟨hal-01090128⟩
Collections
INRIA INRIA2
94 Consultations
147 Téléchargements
