HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
The Effect of Partial Crop Harvest on Biological Pest Control
Sapna Nundloll 1 Ludovic Mailleret 2 Frédéric Grognard 1
1 COMORE - Modeling and control of renewable resources
LOV - Laboratoire d'océanographie de Villefranche, CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : In this paper, the effects of periodic partial harvesting of a continuously grown crop on augmentative biological control are analyzed. Partial harvesting can remove a proportion of both pests and biological control agents, so its influence on the control efficiency cannot be a priori neglected. An impulsive model consisting of a general predator-prey model in ode, augmented by a discrete component to depict releases of biological control agents and the periodic partial harvesting is used. The periods are taken as integer multiples of each other. A stability condition for pest eradication is expressed as the minimal value of the budget per unit time to spend on predators. We consider the partial harvesting period to be fixed by both the plant's physiology and market forces so that the only manipulated variable is the release period. It is shown that varying the release period with respect to the harvest period influences the minimal budget value when the former is carried out more often than the latter and has no effect when releases take place as often as or less frequently than the partial harvests.
Complete list of metadata
https://hal.inria.fr/hal-01090316
Contributor : Jean-Luc Gouzé Connect in order to contact the contributor
Submitted on : Wednesday, December 3, 2014 - 4:02:32 PM
Last modification on : Tuesday, May 10, 2022 - 3:00:38 PM
Long-term archiving on: : Saturday, April 15, 2017 - 1:57:45 AM
File
RMJM.pdf
Identifiers
Citation
Sapna Nundloll, Ludovic Mailleret, Frédéric Grognard. The Effect of Partial Crop Harvest on Biological Pest Control. Rocky Mountain Journal of Mathematics, Rocky Mountain Mathematics Consortium, 2008, 38 (5), pp.1633-1661. ⟨10.1216/RMJ-2008-38-5-1633⟩. ⟨hal-01090316⟩
Share
Metrics
Record views
163
Files downloads
80
