. Criddle, Membrane fouling in an anaerobic membrane bioreactor: Differences in relative abundance of bacterial species in the membrane foulant layer and in suspension, J. Membr. Sci, vol.364, pp.331-338, 2010.
A. Charfi, N. B. Amar, and J. Harmand, Analysis of fouling mechanisms in anaerobic membrane bioreactors, Water Research, vol.46, issue.8, pp.2637-2650, 2012.
DOI : 10.1016/j.watres.2012.02.021
URL : https://hal.archives-ouvertes.fr/hal-00859550
D. P. Saroj, G. Guglielmi, D. Chiarani, and G. Andreottola, Subcritical fouling behavior modelling of membrane bioreactors for municipal wastewater treatment: The prediction of the time to reach critical operating condition, pp.231-175, 2008.
S. Ognier, C. Wisniewski, and A. Grasmick, Membrane bioreactor fouling in sub-critical filtration conditions: a local critical flux concept, Journal of Membrane Science, vol.229, issue.1-2, pp.171-177, 2004.
DOI : 10.1016/j.memsci.2003.10.026
J. Zhang, H. C. Chua, J. Zhou, and A. G. Fane, Foactors affecting the membrane performance in submerged membrane bioreactors, J. Membr. Sci, vol.248, pp.54-66, 2006.
B. D. Cho and A. G. Fane, Fouling transients in nominally sub-critical flux operation of a membrane bioreactor, Journal of Membrane Science, vol.209, issue.2, pp.391-403, 2002.
DOI : 10.1016/S0376-7388(02)00321-6
Y. Ye, P. Le-clech, V. Chen, and A. G. Fane, Evolution of fouling during crossflow filtration of model EPS solutions, Journal of Membrane Science, vol.264, issue.1-2, pp.190-199, 2005.
DOI : 10.1016/j.memsci.2005.04.040
S. Ognier, C. Wisniewski, and A. Grasmick, Membrane fouling during constant flux filtration in membrane bioreactors, Membrane Technology, vol.2002, issue.7, pp.6-10, 2002.
DOI : 10.1016/S0958-2118(02)07018-0
S. Chang, A. G. Fane, and T. D. Waite, Analysis of constant permeate flow filtration using dead-end hollow fiber membranes, Journal of Membrane Science, vol.268, issue.2, pp.132-141, 2006.
DOI : 10.1016/j.memsci.2005.06.010
X. Y. Li and X. M. Wang, Modelling of membrane fouling in a submerged membrane bioreactor, Journal of Membrane Science, vol.278, issue.1-2, pp.151-161, 2006.
DOI : 10.1016/j.memsci.2005.10.051
R. W. Field, D. Wu, J. A. Howell, and B. B. Gupta, Critical flux concept for microfiltration fouling, Journal of Membrane Science, vol.100, issue.3, pp.259-272, 1995.
DOI : 10.1016/0376-7388(94)00265-Z
J. P. De-bruijn, F. N. Salazar, and R. Boroquez, Membrane blocking in ultrafiltration-a new approach to fouling, Trans. IChemE C, Food Bioprod. Process, pp.83-211, 2005.
A. Zarragoitia-gonzalez, S. Schetrite, M. Alliet, U. Jauregui-haza, and C. Albasi, Modelling of submerged membrane bioreactor: conceptual study about link between activated sludge biokinetics, aeration and fouling process, J. Membr. Sci, pp.325-612, 2008.
A. Robles, M. V. Ruano, J. Ribes, A. Seco, and J. Ferrer, A filtration model applied to submerged anaerobic MBRs (SAnMBRs), Journal of Membrane Science, vol.444, pp.444-139, 2013.
DOI : 10.1016/j.memsci.2013.05.021
H. J. Lin, K. Xie, B. Mahendran, D. M. Bagley, K. T. Leung et al., Sludge properties and their effects on membrane fouling in submerged anaerobic membrane bioreactors (AnMBRs), Water Res, pp.43-3827, 2009.
L. D. Hughes and R. W. Field, Crossflow filtration of washed and unwashed yeast suspensions at constant shear under nominally sub-critical conditions, Journal of Membrane Science, vol.280, issue.1-2, pp.89-98, 2006.
DOI : 10.1016/j.memsci.2006.01.022
F. Waeger, T. Delhaye, and W. Fuchs, The use of ceramic microfiltration and ultrafiltration membranes for particle removal from anaerobic digester effluents, Separation and Purification Technology, vol.73, issue.2, pp.73-271, 2010.
DOI : 10.1016/j.seppur.2010.04.013
J. Ho and S. Sung, Effects of solid concentrations and cross-flow hydrodynamics on microfiltration of anaerobic sludge, Journal of Membrane Science, vol.345, issue.1-2, pp.142-147, 2009.
DOI : 10.1016/j.memsci.2009.08.047
M. Heran, R. Aryal, H. K. Shon, S. Vigneswaran, S. Elmaleh et al., How to Optimize Hollow-Fiber Submerged Membrane Bioreactors, Water Environment Research, vol.84, issue.2, pp.115-119, 2012.
DOI : 10.2175/106143011X13206732881877
URL : https://opus.lib.uts.edu.au/bitstream/10453/29578/1/2011005445OK.pdf
H. Li, A. G. Fane, H. G. Coster, and S. Vigneswaran, Direct observation of particle deposition on the membrane surface during crossflow microfiltration, Journal of Membrane Science, vol.149, issue.1, pp.149-83, 1998.
DOI : 10.1016/S0376-7388(98)00181-1
J. Wu, P. Le-clech, R. M. Stuetz, A. G. Fane, and V. Chen, Effects of relaxation and backwashing conditions on fouling in membrane bioreactor, Journal of Membrane Science, vol.324, issue.1-2, pp.324-350, 2008.
DOI : 10.1016/j.memsci.2008.06.057
I. J. Kang, S. H. Yoon, and C. H. Lee, Comparison of the filtration characteristics of organic and inorganic membranes in a membrane-coupled anaerobic bioreactor, Water Research, vol.36, issue.7, pp.1803-1813, 2002.
DOI : 10.1016/S0043-1354(01)00388-8
Y. Lee, J. Cho, Y. Seo, W. L. Jae, and K. H. Ahn, Modeling of submerged membrane bioreactor process for wastewater treatment, Desalination, vol.146, issue.1-3, pp.451-457, 2002.
DOI : 10.1016/S0011-9164(02)00543-X
A. Charfi, J. Harmand, N. B. Amar, A. Grasmick, and M. Heran, Deposit membrane fouling: influence of specific cake layer resistance and tangential shear stresses, Water Science & Technology, vol.70, issue.1, 2014.
DOI : 10.2166/wst.2014.186
URL : https://hal.archives-ouvertes.fr/hal-01090596
A. A. Mccarthy, P. K. Walsh, and G. Foley, Characterising the packing and dead-end filter cake compressibility of the polymorphic yeast Kluyveromyces marxianus var. marxianus NRRLy2415, Journal of Membrane Science, vol.198, issue.1, pp.87-94, 2002.
DOI : 10.1016/S0376-7388(01)00641-X
K. Katsoufidou, S. G. Yiantsios, and A. J. Karabelas, A study of ultrafiltration membrane fouling by humic acids and flux recovery by backwashing: Experiments and modeling, Journal of Membrane Science, vol.266, issue.1-2, pp.40-50, 2005.
DOI : 10.1016/j.memsci.2005.05.009
S. P. Hong, T. H. Bae, T. M. Tak, S. Hong, and A. Randall, Fouling control in activated sludge submerged hollow fiber membrane bioreactors, Desalination, vol.143, issue.3, pp.451-457, 2002.
DOI : 10.1016/S0011-9164(02)00260-6
J. R. Pan, Y. C. Su, C. Huang, and H. C. Lee, Effect of sludge characteristics on membrane fouling in membrane bioreactors, Journal of Membrane Science, vol.349, issue.1-2, pp.287-294, 2010.
DOI : 10.1016/j.memsci.2009.11.055
