Digital Estimation and Compensation of I/Q Imbalance for Full-Duplex Dual-Band OFDM Radio - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
With the increasing demand of wireless applications, current radio transceivers are challenged by the requirement of high data rate and high flexibility. Full-Duplex Dual-Band OFDM radio transceiver is a very promising radio technique to approach this goal. However, the mutual undesirable signal leakages due to the I/Q imbalance in the Full-Duplex Dual-Band RF front-end lead to a significant performance degradation in the radio link. In this paper, a practical and suitable digital I/Q imbalance estimation and compensation method for mitigating the I/Q imbalance in this flexible radio transceivers is developed and evaluated. The developed I/Q imbalance estimation method is based on the character of the frequency-flat-fading of the self-interference channel. The ADS-Matlab co-simulation results show that the developed digital compensation method can significantly reduce the impact of the I/Q imbalance on the Full-Duplex Dual-Band OFDM radio receivers.
Zhaowu_PIMRC2014.pdf (429.34 Ko) Télécharger le fichier
hal-01090698 , version 1 (04-12-2014)
  • HAL Id : hal-01090698 , version 1
Zhaowu Zhan, Guillaume Villemaud, Florin Hutu, Jean-Marie Gorce. Digital Estimation and Compensation of I/Q Imbalance for Full-Duplex Dual-Band OFDM Radio. PIMRC 2014, Sep 2014, Washington, United States. ⟨hal-01090698⟩
208 Consultations
1086 Téléchargements
