A New Homogeneous Quasi-Continuous Second Order Sliding Mode Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new homogeneous quasi-continuous second order sliding mode control algorithm is developed. The Lyapunov function for finite-time stability analysis is constructed. The homogeneity property of the algorithm is analyzed. The chattering attenuation procedure using Lyapunov function of the closed-loop system is discussed. The scheme for control parameters tuning based on linear matrix inequalities is elaborated. The theoretical results are supported by numerical simulations.
Automatique
cla_main.pdf (229.36 Ko) Télécharger le fichier
hal-01090716 , version 1 (04-12-2014)
  • HAL Id : hal-01090716 , version 1
Andrey Polyakov, Isaac Chairez. A New Homogeneous Quasi-Continuous Second Order Sliding Mode Control. XVI Congreso Latinoamericano de Control Automático, Oct 2014, Cancun, Mexico. ⟨hal-01090716⟩
103 Consultations
363 Téléchargements
