V. Andrieu, L. Praly, and A. Astolfi, Homogeneous Approximation, Recursive Observer Design, and Output Feedback, SIAM Journal on Control and Optimization, vol.47, issue.4, pp.1814-1850, 2008.
DOI : 10.1137/060675861
URL : https://hal.archives-ouvertes.fr/hal-00362707
E. Bernuau, D. Efimov, W. Perruquetti, and A. Polyakov, On homogeneity and its application in sliding mode control, Journal of the Franklin Institute, vol.351, issue.4, pp.1866-1901, 2014.
DOI : 10.1016/j.jfranklin.2014.01.007
URL : https://hal.archives-ouvertes.fr/hal-00942326
E. Bernuau, A. Polyakov, D. Efimov, and W. Perruquetti, On extension of homogeneity notion for differential inclusions, Proceeding of the European Control Conference, pp.2204-2209, 2013.
URL : https://hal.archives-ouvertes.fr/hal-00801818
S. P. Bhat and D. S. Bernstein, Finite-Time Stability of Continuous Autonomous Systems, SIAM Journal on Control and Optimization, vol.38, issue.3, pp.751-766, 2000.
DOI : 10.1137/S0363012997321358
W. Carpenter, On the Solution of the Real Quartic, Mathematics Magazine, vol.39, issue.1, pp.28-30, 1966.
DOI : 10.2307/2688990
R. Courant and F. John, Introduction to calculus and analysis (, 2000.
C. Edwards and S. Spurgeon, Sliding Mode Control: Theory And Applications, 1998.
A. F. Filippov, Differential equations with discontinuous right-hand side, 1988.
DOI : 10.1090/trans2/042/13
H. Hermes, Nilpotent Approximations of Control Systems and Distributions, SIAM Journal on Control and Optimization, vol.24, issue.4, pp.731-736, 1986.
DOI : 10.1137/0324045
A. Levant, Sliding order and sliding accuracy in sliding mode control, International Journal of Control, vol.51, issue.6, pp.1247-1263, 1993.
DOI : 10.1109/TAC.1977.1101661
A. Levant, Homogeneity approach to high-order sliding mode design, Automatica, vol.41, issue.5, pp.823-830, 2005.
DOI : 10.1016/j.automatica.2004.11.029
A. Levant, Quasi-continuous high-order sliding-mode controllers, IEEE Transactions on Automatic Control, vol.50, issue.11, pp.1812-1816, 2005.
DOI : 10.1109/TAC.2005.858646
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.218.4061
A. Levant, Principles of 2-sliding mode design, Automatica, vol.43, issue.4, pp.576-586, 2007.
DOI : 10.1016/j.automatica.2006.10.008
J. Moreno, Strict Lyapunov Functions for the Super-Twisting Algorithm, IEEE Transactions on Automatic Control, vol.57, issue.4, pp.1035-1040, 2012.
DOI : 10.1109/TAC.2012.2186179
H. Nakamura, N. Nakamura, and H. Nishitani, Stabilization of homogeneous systems using implicit control lyhapunov functions, 7th IFAC Symposium on Nonlinear Control Systems, pp.561-566, 2007.
Y. Orlov, Finite Time Stability and Robust Control Synthesis of Uncertain Switched Systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005.
DOI : 10.1137/S0363012903425593
A. Polyakov, D. Efimov, and W. Perruquetti, Finite-time Stabilization Using Implicit Lyapunov Function Technique, 9th Symposium on Nonlinear Control Systems, pp.140-145, 2013.
DOI : 10.3182/20130904-3-FR-2041.00043
URL : https://hal.archives-ouvertes.fr/hal-00844386
A. Polyakov and L. Fridman, Stability notions and Lyapunov functions for sliding mode control systems, Journal of the Franklin Institute, vol.351, issue.4, pp.1831-1865, 2014.
DOI : 10.1016/j.jfranklin.2014.01.002
URL : https://hal.archives-ouvertes.fr/hal-00942319
A. Polyakov and A. Poznyak, Lyapunov function design for finite-time convergence analysis: ???Twisting??? controller for second-order sliding mode realization, Automatica, vol.45, issue.2, pp.444-448, 2009.
DOI : 10.1016/j.automatica.2008.07.013
A. Polyakov and A. Poznyak, Unified Lyapunov function for a finite-time stability analysis of relay second-order sliding mode control systems, IMA Journal of Mathematical Control and Information, vol.29, issue.4, pp.529-550, 2012.
DOI : 10.1093/imamci/dns007
L. Rosier, Homogeneous Lyapunov function for homogeneous continuous vector field, Systems & Control Letters, vol.19, issue.6, pp.467-473, 1992.
DOI : 10.1016/0167-6911(92)90078-7
E. Roxin, On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.XV, issue.3, pp.273-283, 1966.
DOI : 10.1007/BF02844106
Y. Shtessel, C. Edwards, L. Fridman, and A. Levant, Sliding Mode Control and Observation, 2014.
DOI : 10.1007/978-0-8176-4893-0
V. I. Utkin, Variable structure systems with sliding modes, IEEE Transactions on Automatic Control, vol.22, issue.2, pp.212-222, 1977.
DOI : 10.1109/TAC.1977.1101446
V. I. Utkin, J. Guldner, and J. Shi, Sliding mode control on electro-mechanical systems, Mathematical Problems in Engineering, vol.8, issue.4-5, 2009.
DOI : 10.1080/10241230306724
V. I. Zubov, On systems of ordinary differential equations with generalized homogenous right-hand sides. Izvestia vuzov, Mathematica. (in Russian), vol.1, pp.80-88, 1958.
