Weak Convergence of a Mass-Structured Individual-Based Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematics and Optimization Année : 2015
We propose a model of chemostat where the bacterial population is individually-based, each bacterium is explicitly represented and has a mass evolving continuously over time. The substrate concentration is represented as a conventional ordinary differential equation. These two components are coupled with the bacterial consumption. Mechanisms acting on the bacteria are explicitly described (growth, division and washout). Bacteria interact via consumption. We set the exact Monte Carlo simulation algorithm of this model and its mathematical representation as a stochastic process. We prove the convergence of this process to the solution of an integro-differential equation when the population size tends to infinity. Finally, we propose several numerical simulations
Fichier non déposé
hal-01090727 , version 1 (04-12-2014)
Fabien Campillo, Coralie Fritsch. Weak Convergence of a Mass-Structured Individual-Based Model. Applied Mathematics and Optimization, 2015, 72 (1), pp.37-73. ⟨10.1007/s00245-014-9271-3⟩. ⟨hal-01090727⟩
247 Consultations
0 Téléchargements
