B. Bonnard and J. Caillau, Riemannian metric of the averaged energy minimization problem in orbital transfer with low thrust, Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.24, issue.3, pp.395-411, 2007.
DOI : 10.1016/j.anihpc.2006.03.013
URL : https://hal.archives-ouvertes.fr/hal-00540258
B. Bonnard and J. Caillau, Geodesic flow of the averaged controlled Kepler equation, Forum Mathematicum, vol.21, issue.5, pp.797-814, 2009.
DOI : 10.1515/FORUM.2009.038
URL : https://hal.archives-ouvertes.fr/hal-00134702
A. E. Bryson, J. , and Y. Ho, Applied optimal control, 1975.
C. Carathéodory, Calculus of variations and partial differential equations of the first order. Part I: Partial differential equations of the first order, 1982.
A. Celletti and L. Chierchia, KAM Stability for a three-body problem of the Solar system, Zeitschrift f??r angewandte Mathematik und Physik, vol.57, issue.1, pp.33-41, 2006.
DOI : 10.1007/s00033-005-0002-0
O. Cots, Contrôle optimal géométrique: méthodes homotopiques et applications, 2012.
R. C. Domingos, R. Vilhena-de-moraes, A. F. Bertachini-de-almeida, and . Prado, Third-Body Perturbation in the Case of Elliptic Orbits for the Disturbing Body, Mathematical Problems in Engineering, vol.23, issue.3, 2008.
DOI : 10.1007/BF01229141
T. N. Edelbaum, Optimum low-thrust rendezvous and station keeping, AIAA Journal, vol.2, issue.7, pp.1196-1201, 1964.
DOI : 10.2514/3.2521
T. N. Edelbaum, Optimum power-limited orbit transfer in strong gravity fields, AIAA Journal, vol.3, issue.5, pp.921-925, 1965.
DOI : 10.2514/3.3016
S. Geffroy, Généralisation des techniques de moyennation en contrôle optimal, application auxprobì emes de rendez-vous orbitauxàorbitauxà poussée faible, 1997.
S. Geffroy and R. Epenoy, Optimal low-thrust transfers with constraints---generalization of averaging techniques, Acta Astronautica, vol.41, issue.3, pp.133-149, 1997.
DOI : 10.1016/S0094-5765(97)00208-7
V. V. Nemytskii and V. V. Stepanov, Qualitative theory of differential equations, 1960.
DOI : 10.1515/9781400875955
G. Pascoli, Astronomie fondamentale, 2000.
L. S. Pontryagin, V. G. Boltyanskii, R. V. Gamkrelidze, and E. F. Mishchenko, The mathematical theory of optimal processes, 1962.
J. P. Vinti, G. J. Der, and N. L. Bonavito, Orbital and celestial mechanics, 1998.
DOI : 10.2514/4.866487
O. Zarrouati, Trajectoires spatiales, CEPADUES-EDITIONS, 1987.
