Aggregation of Partial Rankings, p-Ratings and Top-m Lists, Algorithmica, vol.3, issue.3, pp.284-300, 2010. ,
DOI : 10.1007/s00453-008-9211-1
Effective mapping of biomedical text to the umls metathesaurus: the metamap program, Proceedings of the AMIA Symposium, p.17, 2001. ,
The Unified Medical Language System (UMLS): integrating biomedical terminology, Nucleic Acids Research, vol.32, issue.90001, pp.267-270, 2004. ,
DOI : 10.1093/nar/gkh061
Mémoire sur lesélectionlesélection au scrutin. Histoire de l'academie royal des sciences, pp.657-664 ,
The use of the area under the roc curve in the evaluation of machine learning algorithms, Pattern Recognition, vol.30, pp.1145-1159, 1997. ,
Gene List significance at-a-glance with GeneValorization, Bioinformatics, vol.27, issue.8, pp.271187-1189, 2011. ,
DOI : 10.1093/bioinformatics/btr073
URL : https://hal.archives-ouvertes.fr/inria-00627865
Using Medians to Generate Consensus Rankings for Biological Data, Proc. SSDBM: Scientific and Statistical Database Management Conference, pp.73-90, 2011. ,
DOI : 10.1007/978-3-540-77918-6_21
URL : https://hal.archives-ouvertes.fr/inria-00584690
A knowledge-based approach to medical records retrieval, TREC, 2011. ,
Rank aggregation methods for the Web, Proceedings of the tenth international conference on World Wide Web , WWW '01, pp.613-622, 2001. ,
DOI : 10.1145/371920.372165
Efficient similarity search and classification via rank aggregation, Proceedings of the 2003 ACM SIGMOD international conference on on Management of data , SIGMOD '03, pp.301-312, 2003. ,
DOI : 10.1145/872757.872795
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.12.2124
Comparing and aggregating rankings with ties, Proceedings of the twenty-third ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '04, pp.47-58, 2004. ,
DOI : 10.1145/1055558.1055568
A NEW MEASURE OF RANK CORRELATION, Biometrika, vol.30, issue.1-2, pp.81-89, 1938. ,
DOI : 10.1093/biomet/30.1-2.81
Medical subject headings (mesh), Bulletin of the Medical Library Association, vol.88, issue.3, p.265, 2000. ,
Entrez gene: gene-centered information at ncbi. Nucleic acids research, pp.52-57, 2011. ,
DOI : 10.1093/nar/gkq1237
URL : http://doi.org/10.1093/nar/gkq1237
Database resources of the national center for biotechnology information, Nucleic acids research, vol.39, issue.1, pp.38-51, 2011. ,
Snomed clinical terms: overview of the development process and project status, Proceedings of the AMIA Symposium, p.662, 2001. ,
Counterexamples in topology, 1978. ,
Bioportal: enhanced functionality via new web services from the national center for biomedical ontology to access and use ontologies in software applications, Nucleic acids research, issue.2, pp.39-541, 2011. ,
