Block filtering decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerical Linear Algebra with Applications Année : 2014
This paper introduces a new preconditioning technique that is suitable for matrices arising from the discretization of a system of PDEs on unstructured grids. The preconditioner satisfies a so-called filtering property, which ensures that the input matrix is identical with the preconditioner on a given filtering vector. This vector is chosen to alleviate the effect of low-frequency modes on convergence and so decrease or eliminate the plateau that is often observed in the convergence of iterative methods. In particular, the paper presents a general approach that allows to ensure that the filtering condition is satisfied in a matrix decomposition. The input matrix can have an arbitrary sparse structure. Hence, it can be reordered using nested dissection, to allow a parallel computation of the preconditioner and of the iterative process. We show the efficiency of our preconditioner through a set of numerical experiments on symmetric and nonsymmetric matrices.
hal-01091252 , version 1 (05-12-2014)
Riadh Fezzani, Laura Grigori, Frédéric Nataf, Ke Wang. Block filtering decomposition. Numerical Linear Algebra with Applications, 2014, 21 (6), pp.18. ⟨10.1002/nla.1921⟩. ⟨hal-01091252⟩
254 Consultations
0 Téléchargements
