Verifying Modal Workflow Specifications Using Constraint Solving
Nowadaysworkflowsareextensivelyusedbycompaniestoimproveorganizationalefficiencyandproductivity.Thispaperfocusesontheverificationofmodalworkflowspecificationsusingconstraintsolvingasacomputationaltool.ItsmaincontributionconsistsindevelopinganinnovativeformalframeworkbasedonconstraintsystemstomodelexecutionsofworkflowPetrinetsandtheirstructuralproperties,aswellastoverifytheirmodalspecifications.Finally,animplementationandpromisingexperimentalresultsconstituteapracticalcontribution.
