A Tactic Language for the System Coq, LPAR, pp.85-95, 1955. ,
DOI : 10.1007/3-540-44404-1_7
URL : https://hal.archives-ouvertes.fr/hal-01125070
Hybrid, Journal of Automated Reasoning, vol.18, issue.1, pp.43-105, 2012. ,
DOI : 10.1007/s10817-010-9194-x
The next 700 challenge problems for reasoning with higherorder abstract syntax representations: Part 1?A foundational view, 2014. ,
The next 700 challenge problems for reasoning with higherorder abstract syntax representations: Part 2?A survey, 2014. ,
The Abella Interactive Theorem Prover (System Description), Proceedings of the International Joint Conference on Automated Reasoning, pp.154-161, 2008. ,
DOI : 10.1007/978-3-540-71070-7_13
A Framework for Specifying, Prototyping, and Reasoning about Computational Systems, 2009. ,
Nominal abstraction, Information and Computation, vol.209, issue.1, pp.48-73, 2011. ,
DOI : 10.1016/j.ic.2010.09.004
URL : http://doi.org/10.1016/j.ic.2010.09.004
A Two-Level Logic Approach to Reasoning About Computations, Journal of Automated Reasoning, vol.40, issue.4, pp.241-273, 2012. ,
DOI : 10.1007/s10817-011-9218-1
URL : https://hal.archives-ouvertes.fr/hal-00776208
A computational logic approach to syntax and semantics, Presented at the Tenth Symposium of the Mathematical Foundations of Computer Science, IBM Japan, 1985. ,
Programming with Higher-Order Logic, CUP, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00776197
A proof theory for generic judgments: an extended abstract, 18th Annual IEEE Symposium of Logic in Computer Science, 2003. Proceedings., pp.118-127, 2003. ,
DOI : 10.1109/LICS.2003.1210051
Contextual modal type theory, ACM Transactions on Computational Logic, vol.9, issue.3, pp.1-49, 2008. ,
DOI : 10.1145/1352582.1352591
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.1028.3796
Higher-order abstract syntax, PLDI, pp.199-208, 1988. ,
Twelf User's Guide, 2002. ,
System Description: Twelf ??? A Meta-Logical Framework for Deductive Systems, pp.202-206, 1999. ,
DOI : 10.1007/3-540-48660-7_14
Beluga: A Framework for Programming and Reasoning with Deductive Systems (System Description), IJCAR, pp.15-21, 2010. ,
DOI : 10.1007/978-3-642-14203-1_2
The Teyjus system ? version 2, 2008. ,
Nominal unification, Theoretical Computer Science, vol.323, issue.1-3, pp.473-497, 2004. ,
DOI : 10.1016/j.tcs.2004.06.016
Reasoning about higher-order relational specifications, Proceedings of the 15th Symposium on Principles and Practice of Declarative Programming, PPDP '13, pp.157-168, 2013. ,
DOI : 10.1145/2505879.2505889
URL : https://hal.archives-ouvertes.fr/hal-00787126
