Abstract : This paper presents a saturated proportional controller that achieves depollution of wastewater in a continuous anaerobic digester. This goal is reached by defining a region of the state-space where the depollution is achieved and forcing attractivity and invariance of this region. The control variable is the dilution rate and the controlled variable is a linear combination (S λ) of the substrate concentrations, that could be the Chemical Oxygen Demand (COD) or the Biological Oxygen Demand (BOD), depending on the value of λ. No measurement of the substrate concentration in the input flow is required; the only necessary measurement is S λ .
https://hal.inria.fr/hal-01091729 Contributor : Frédéric GrognardConnect in order to contact the contributor Submitted on : Friday, December 5, 2014 - 10:18:02 PM Last modification on : Friday, February 4, 2022 - 3:12:07 AM Long-term archiving on: : Monday, March 9, 2015 - 6:06:18 AM
Frédéric Grognard, Olivier Bernard. Stability analysis of a wastewater treatment plant with saturated control. 6th International Symposium on Systems Analysis and Integration Assessment (WATERMATEX 2004), Nov 2004, Beijing, China. ⟨hal-01091729⟩
