The CompCert C verified compiler: Documentation and user’s manual - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2015
This document is the user’s manual for the CompCert C verified compiler. It is organized as follows: Chapter 1 gives an overview of the CompCert C compiler and of the formal verification of compilers. Chapter 2 explains how to install CompCert C. Chapter 3 explains how to use the CompCert C compiler. Chapter 4 explains how to use the CompCert C reference interpreter. Chapter 5 describes the subset of the ISO C99 language that is implemented by CompCert. Chapter 6 describes the supported language extensions: pragmas, attributes, built-in functions. Chapter 7 describes the experimental tool cchecklink that validates a posteriori the correctness of assembling and linking the code produced by the CompCert C compiler.
manual.pdf (284.75 Ko) Télécharger le fichier
hal-01091802 , version 1 (06-12-2014)
hal-01091802 , version 2 (22-12-2015)
hal-01091802 , version 3 (22-12-2015)
hal-01091802 , version 4 (09-12-2016)
hal-01091802 , version 5 (05-11-2017)
hal-01091802 , version 6 (09-11-2018)
hal-01091802 , version 7 (19-11-2019)
hal-01091802 , version 8 (09-12-2020)
hal-01091802 , version 9 (18-12-2021)
hal-01091802 , version 10 (06-12-2022)
hal-01091802 , version 11 (05-12-2023)
  • HAL Id : hal-01091802 , version 2
Xavier Leroy. The CompCert C verified compiler: Documentation and user’s manual: Version 2.5. [Intern report] Inria. 2015. ⟨hal-01091802v2⟩
1240 Consultations
3957 Téléchargements
