Named data aggregation in wireless sensor networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we present a novel named data aggregation method dedicated to wireless sensor networks. The method relies on an adaptation of the CCNx protocol implementation that we have extended with in-network processing functions to aggregate named data efficiently. We have implemented and tested our solution with the Contiki operating system which is an operating system for resources-constrained embedded systems and wireless sensor networks. Our simulation and measurement results using the Cooja simulator and physical nodes show that our solution has a small overhead in terms of exchanged messages and provides acceptable data retrieval delays.
Mots clés
iot_ccn.pdf (2.13 Mo) Télécharger le fichier
hal-01092025 , version 1 (10-12-2014)
Younes Abid, Bilel Saadallah, Abdelkader Lahmadi, Olivier Festor. Named data aggregation in wireless sensor networks. IEEE Network Operations and Management Symposium (NOMS), 2014, May 2014, cracovie, Poland. pp.1 - 8, ⟨10.1109/NOMS.2014.6838364⟩. ⟨hal-01092025⟩
256 Consultations
333 Téléchargements
