Decentralized control of partially observable Markov decision processes, 52nd IEEE Conference on Decision and Control, 2013. ,
DOI : 10.1109/CDC.2013.6760239
Incremental policy generation for finite-horizon DEC-POMDPs, ICAPS, 2009. ,
An investigation into mathematical programming for finite horizon decentralized POMDPs, JAIR, vol.37, pp.329-396, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00439627
Solving transition independent decentralized Markov decision processes, JAIR, vol.22, pp.423-455, 2004. ,
Policy iteration for decentralized control of Markov decision processes, JAIR, vol.34, pp.89-132, 2009. ,
The Complexity of Decentralized Control of Markov Decision Processes, Mathematics of Operations Research, vol.27, issue.4, 2002. ,
DOI : 10.1287/moor.27.4.819.297
Exact dynamic programming for decentralized POMDPs with lossless policy compression, ICAPS, pp.20-27, 2008. ,
Stochastic dynamic programming with factored representations, Artificial Intelligence, vol.121, issue.1-2, pp.49-107, 2000. ,
DOI : 10.1016/S0004-3702(00)00033-3
Existential arc consistency: Getting closer to full arc consistency in weighted CSPs, IJCAI, pp.84-89, 2005. ,
Bucket elimination: a unifying framework for processing hard and soft constraints, ACM Computing Surveys, vol.28, issue.4es, pp.51-55, 1997. ,
DOI : 10.1145/242224.242302
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.43.9602
Bucket elimination: A unifying framework for reasoning, Artificial Intelligence, vol.113, issue.1-2, pp.41-85, 1999. ,
DOI : 10.1016/S0004-3702(99)00059-4
URL : http://doi.org/10.1016/s0004-3702(99)00059-4
Optimally solving Dec-POMDPs as continuous-state MDPs, IJCAI, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00907338
Scaling up decentralized MDPs through heuristic search, UAI, pp.217-226, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00765221
Producing efficient error-bounded solutions for transition independent decentralized MDPs, AAMAS, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00918066
Multiagent planning with factored MDPs, NIPS, pp.1523-1530, 2001. ,
Efficient solution algorithms for factored MDPs, J. Artif. Intell. Res. (JAIR), vol.19, pp.399-468, 2003. ,
Computing factored value functions for policies in structured MDPs Constraint-based dynamic programming for decentralized POMDPs with structured interactions, IJCAI AAMAS, pp.1332-1339, 1999. ,
Point-based backup for decentralized POMDPs: complexity and new algorithms, AAMAS, pp.1315-1322, 2010. ,
Scalable multiagent planning using probabilistic inference, IJCAI, pp.2140-2146, 2011. ,
Solving factored MDPs with hybrid state and action variables, J. Artif. Intell. Res. (JAIR), vol.27, pp.153-201, 2006. ,
Not all agents are equal: scaling up distributed POMDPs for agent networks, AAMAS (1), pp.485-492, 2008. ,
Networked distributed POMDPs: A synthesis of distributed constraint optimization and POMDPs, AAAI, pp.133-139, 2005. ,
Decentralized POMDPs, Reinforcement Learning: State of the Art, pp.471-503, 2012. ,
DOI : 10.1007/978-3-642-27645-3_15
Sufficient plan-time statistics for decentralized POMDPs, IJCAI, 2013. ,
Incremental clustering and expansion for faster optimal planning in Dec-POMDPs, pp.449-509, 2013. ,
Lossless clustering of histories in decentralized POMDPs, AAMAS, pp.577-584, 2009. ,
Influence-based abstraction for multiagent systems, AAAI, 2012. ,
Greedy linear value-approximation for factored Markov decision processes, AAAI/IAAI, pp.285-291, 2002. ,
A bilinear programming approach for multiagent planning, JAIR, vol.35, pp.235-274, 2009. ,
Markov Decision Processes, Discrete Stochastic Dynamic Programming, 1994. ,
The Optimal Control of Partially Observable Markov Processes over a Finite Horizon, Operations Research, vol.21, issue.5, pp.1071-1088, 1973. ,
DOI : 10.1287/opre.21.5.1071
Heuristic search value iteration for POMDPs, Proc. of UAI, pp.520-527, 2004. ,
MAA*: A heuristic search algorithm for solving decentralized POMDPs, UAI, pp.568-576, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00000204
Letting loose a SPIDER on a network of POMDPs, Proceedings of the 6th international joint conference on Autonomous agents and multiagent systems , AAMAS '07, 2007. ,
DOI : 10.1145/1329125.1329388
Influence-based policy abstraction for weakly-coupled Dec-POMDPs, ICAPS, pp.185-192, 2010. ,
