A Formal Approach to Incremental Converter Synthesis for System-on-Chip Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Design Automation of Electronic Systems Année : 2014
A system-on-chip (SoC) contains numerous intellectual property blocks, or IPs. Protocol mismatches between IPs may affect the system-level functionality of the SoC. Mismatches are addressed by introducing converters to control inter-IP interactions. Current approaches towards converter generation find limited practical application as they use restrictive models, lack formal rigour, handle a small subset of commonly encountered mismatches, and/or are not scalable. We propose a formal technique for SoC design using incremental converter synthesis. The proposed formulation provides precise models for protocols and requirements, and provides a scalable algorithm that allows adding multiple components and requirements to an SoC incrementally. We prove that the technique is sound and complete. Experimental results obtained using real-life AMBA benchmarks show the scalability and wide range of mismatches handled by our approach.
Fichier non déposé
hal-01092255 , version 1 (08-12-2014)
Roopak Sinha, Alain Girault, Gregor Gössler, Partha Roop. A Formal Approach to Incremental Converter Synthesis for System-on-Chip Design. ACM Transactions on Design Automation of Electronic Systems, 2014, 20, pp.30. ⟨10.1145/2663344⟩. ⟨hal-01092255⟩
144 Consultations
0 Téléchargements
