Abstract : We show that it is possible to define a realizability interpretation for the Σ 2 -fragment of classical Analysis using Gödel's System T only. This supplements a previous result of Schwichtenberg regarding bar recursion at types 0 and 1 by showing how to avoid using bar recursion altogether. Our result is proved via a conservative extension of System T with an operator for composable continuations from the theory of programming languages due to Danvy and Filinski. The fragment of Analysis is therefore essentially con-structive, even in presence of the full Axiom of Choice schema: Weak Church's Rule holds of it in spite of the fact that it is strong enough to refute the formal arithmetical version of Church's Thesis.
