2PPRIME - Institut Pprime (Institut PPRIME : Recherche et Ingénierie en Matériaux, Mécanique et Energétique
SP2MI Téléport 2
Boulevard Pierre et Marie Curie
BP 30179
86962 FUTUROSCOPE CEDEX - France)
Université de Poitiers : UPR3346 (15, rue de l'Hôtel Dieu - 86034 Poitiers Cedex - France)
Abstract : The case of a turbulent round jet impinging perpendicularly onto a rotating, heated disc is investigated, aiming at understanding the mechanisms at the origin of the influence of rotation on the radial wall jet and associated heat transfer. The present study is based on the complementary use of an analysis of the order of magnitudes of the terms of the mean momentum and Reynolds stress transport equations, available experiments and dedicated Reynolds-Averaged Navier–Stokes (RANS) computations with refined turbulence models. The analysis identifies a scenario for the appearance of rotational effects when the rotation rate is gradually increased.
https://hal.inria.fr/hal-01092833 Contributor : Remi ManceauConnect in order to contact the contributor Submitted on : Tuesday, December 9, 2014 - 3:45:24 PM Last modification on : Thursday, January 20, 2022 - 5:30:56 PM Long-term archiving on: : Tuesday, March 10, 2015 - 11:56:22 AM
Remi Manceau, R. Perrin, M. Hadžiabdić, S. Benhamadouche. Analysis of the effects of rotation on an axisymmetric wall Jet. Proc. 8th Int. Symp. Turb. Shear Flow Phenomena, Poitiers, France, Aug 2013, Poitiers, France. ⟨hal-01092833⟩
