Code Saturne: A Finite Volume Code for the Computation of Turbulent Incompressible flows -Industrial Applications, Int. J. on Finite, issue.0655, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-01115371
A. 1963 Hydrodynamic resistance and the heat loss of rotating solids ,
The wall jet, Journal of Fluid Mechanics, vol.23, issue.06, pp.625-643, 1956. ,
DOI : 10.1017/S002211205600041X
/k)? f turbulence model and its application to forced and natural convection, Proc. 6th ERCOFTAC Int. Symp. on Eng. Turb. Modelling and Measurements, 2005. ,
A robust near-wall elliptic-relaxation eddy-viscosity turbulence model for CFD, International Journal of Heat and Fluid Flow, vol.25, issue.6, pp.1047-1051, 2004. ,
DOI : 10.1016/j.ijheatfluidflow.2004.07.005
The influence of Prandtl number and surface roughness on the resistance of the laminar sub-layer to momentum and heat transfer, Prog. Heat Mass Transfer, vol.1, pp.193-329, 1969. ,
Elliptic blending model: A new near-wall Reynolds-stress turbulence closure, Physics of Fluids, vol.14, issue.2, pp.744-754, 2002. ,
DOI : 10.1063/1.1432693
Turbulent jet impinging onto a rotating disc: a collaborative evaluation of RANS models, Proceedings of the Sixth International Symposium On Turbulence, Heat and Mass Transfer, 2009. ,
DOI : 10.1615/ICHMT.2009.TurbulHeatMassTransf.1390
URL : https://hal.archives-ouvertes.fr/hal-00524548
Two-equation eddy-viscosity turbulence models for engineering applications, AIAA Journal, vol.32, issue.8, pp.1598-1605, 1994. ,
DOI : 10.2514/3.12149
Development of turbulent impinging jet on a rotating disk, International Journal of Heat and Fluid Flow, vol.25, issue.5, pp.759-766, 2004. ,
DOI : 10.1016/j.ijheatfluidflow.2004.05.013
Modeling and Simulation of Turbulent Heat Transfer, chap. Unstructured large-eddyand conjugate heat transfer simulations of wall-bounded flows, 2004. ,
Local Heat Transfer From a Rotating Disk in an Impinging Round Jet, Journal of Heat Transfer, vol.108, issue.2, pp.357-364, 1986. ,
DOI : 10.1115/1.3246929
