1PPRIME - Institut Pprime (Institut PPRIME : Recherche et Ingénierie en Matériaux, Mécanique et Energétique
SP2MI Téléport 2
Boulevard Pierre et Marie Curie
BP 30179
86962 FUTUROSCOPE CEDEX - France)
Université de Poitiers : UPR3346 (15, rue de l'Hôtel Dieu - 86034 Poitiers Cedex - France)
Abstract : This paper is concerned with the analysis of the flow structures responsible for the wall pressure fluctuations predicted by DDES near a reattachment. To this aim, a simulation of the flow over a thick plate is considered. It observed that the linear part of sources is dominant upstream of the reattachment, and that quadratic sources dominate downstream. This is associated with the rapid loss of coherence of the vortices shed from the separated shear layer in the downstream region. Furthermore, it is shown that linear stochastic estimation of the velocity field from the wall pressure well reproduce the linear sources, with negligible quadratic sources.
https://hal.inria.fr/hal-01092886 Contributor : Remi ManceauConnect in order to contact the contributor Submitted on : Tuesday, December 9, 2014 - 4:33:16 PM Last modification on : Thursday, January 20, 2022 - 5:30:56 PM Long-term archiving on: : Tuesday, March 10, 2015 - 12:05:44 PM
T. T. Tran, R. Perrin, Remi Manceau, J. Borée, P. Jordan. Flow sources of wall pressure fluctuations resolved by DDES in a reattaching flow region. Proc. 8th Int. Symp. Turb. Shear Flow Phenomena, Aug 2013, Poitiers, France. ⟨hal-01092886⟩
